transmission fluid leakfrom vent
Old Apr 1, 2015 | 06:13 PM
02jagstype's Avatar
Default transmission fluid leakfrom vent
Hello, I recently purchased a 02 jaguar s type sport 3.0 and am having an issue with a leak. It appears I'm leaking fluid out of the vent tube where it connects up at the engine and its leaking down the sides and making its way to the inspection plate. There is also some fluid on outside passenger side of gearbox. I have checked the cooler lines and they are in good shape. It seems to leak a lot more the harder it is driven.could it have been overfilled from previous owner? Or a seal is bad ? I'm not getting any check lights and its shifting smooth, Any ideas would be greatly appreciated,thanks
Old Apr 1, 2015 | 08:04 PM
Jimmy 68's Avatar
This should help:
https://www.jaguarforums.com/forum/s...t-tube-136579/
Oops, you have an '02, different transmission, yours is a 5R55x, but maybe you can get an idea
Old Apr 1, 2015 | 08:24 PM
02jagstype's Avatar
Thanks, I'm hoping its just overfilled and will stop.it is only leaking when transmission is in a gear. Won't leak when its sitting parked or idling.
Old Apr 2, 2015 | 03:02 AM
JagV8's Avatar
An 02 should not have the ZF, it should be 5R55N if auto. Lots of info on the net but it's hard to overfill!
Old Apr 2, 2015 | 07:01 AM
02jagstype's Avatar
Yes it has the 5r55n
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
picard
Oct 12, 2015 11:56 AM
SeanU
US Northeast
Sep 20, 2015 12:46 PM
chatmanx
Sep 11, 2015 07:17 PM
