Turn Signal Lamp?!
Old Dec 31, 2007 | 05:54 PM
reddrawf's Avatar
Default Turn Signal Lamp?!
My left rear turn signal light is out. Anyone know how I go about changing it? How do you remove the tail light assembly?
Old Jan 1, 2008 | 03:05 AM
momo's Avatar
Default RE: Turn Signal Lamp?!
Basically if you are looking at the back side of the taillight, there are either two or three tabs that you push in and the whole unit comes apart. This exposes they entire assembly that holds the lights. I had to replaced a burned out light and the only place I found that carried the light was Napa Auto parts, so take yourlight with you to make sure it’s the same one.
Old Jan 1, 2008 | 10:46 AM
reddrawf's Avatar
Thanks. The tabs are around the edges I assume? I took a qick look but didn't see anything. I'll take a closer look after it warms up a little today.
Old Jan 1, 2008 | 04:35 PM
reddrawf's Avatar
I looked again and pushed and prodded some. I was too scared of breaking anything to be too forceful. I could not figure it out.
Old Jan 9, 2008 | 07:04 PM
reddrawf's Avatar
Thanks to 02JagSport for posting the diagrams. I finally got around to removing the tail light assembly and removing the dead bulb. Unfortunetly, Autozone was out of stock on the bulb and I had to order it. It should arrive in a couple of days. I also bought replacements for the other tail lights figuring that if I was going to go to all this trouble I might as well replace all the bulbs. Here is the process:
1. Lift the spare tire cover and remove the two screwssecuring the luggage trim piece
2. Carefully pull the bottom of the trim piece away to pop off the plastic rivets.
3. Remove the luggage trim
4.Remove the plastic bolt (it screws off) and carefully pull away the trim piece on the side wall
5. Press the two tabs on the tail light assembly and pull it back
6. You can now gently push the bulb down and turn it to remove it
Picture of the screws, etc.
This is how I did it. Obviously this is not intended to be a how to manual. I just thought it might be helpful to anyone trying to replace the tail light themselves. I didn't find it technically difficult I was just concerned about not breaking anything.
Oh, and if you are like me you'll be appalled at the dirt and spots under that trim! I'll be cleaning that up before putting it back together.
Old Jan 20, 2008 | 02:31 PM
reddrawf's Avatar
Update: I finaly got the turn signal bulb. Autozone ordered them for me. I replaced all the bulbs on the left side (there are 4 different bulb types!). Well, the turn signal works now but the brake light doesn't work! I'm going to drop by the dealer tomorrow to see if I can pick up the correct bulb from them to see if that fixes it. Hopefully I didn't break something trying to fix it!
Old Jan 21, 2008 | 04:39 PM
reddrawf's Avatar
Update again.
Jeez! I went to the dealer and bought a new brake light and tail light for $20. Put them in and still no joy. Now it says the tail light is out and the trunk is ajar, but the turn signal works.I gave up and took it to the dealer. It's there now.
Old Jan 25, 2008 | 08:46 PM
reddrawf's Avatar
Final update on the saga.
The dealer says a fuse was blown and I damaged the truck open sensor when I removed the truck cover. So $300 bucks later my tail light problem is fixed.
Don't get me wrong, I love Jaguars, but it just sucks that is is so darn difficult to change a friggin tail light!
Old Jan 26, 2008 | 01:17 AM
H20boy's Avatar
ORIGINAL: reddrawf
That's just wrong. Sensor damaged during removal of a cover? Hmmmmm
Old Jan 28, 2008 | 06:35 AM
momo's Avatar
ORIGINAL: h20boy
ORIGINAL: reddrawf
^^^^^^ I would have asked for proof? How the frap does one damage the sensor? Where is it located? I still don't get it? You had a blown light, so you replace it and nothing happens, you get new OEM Jag lights and still nothing? Thats when you take it to the dealer and they tell you that you had a bad fuse and you killed your trunk sensor? If you truly had a blown fuse why did your other tailight work? It just doesn't add up...
[sm=wtf.gif]
Old Jan 28, 2008 | 08:04 PM
reddrawf's Avatar
I must not have explained myself well. Sorry for the confsuion.
I replaced the turn signal and it worked but the brake light and tail light didn't. I tired putting new bulbs in for the brake and tail light but they did not work either so I went to buy OEM ones. Still no joy.Then the "Trunk Open" mesage started coming on even though the truck was closed. It seemed to all happen at once or at least one after another. I don't see how I could have damaged the trunk sensor but the error mesage was displaying before I took it to the dealer so they did not make that up.
So the dealer fixed it. Then driving that night I discover one of the headlights is not working. These are the brand new headlights the dealer had replaced a few weeks ago. I took the car back on Saturday and today they have it fixed. Soemthing about a bad balast. Anyway this fix was free. I pick up the car in the morning.
I think I've been treated fairly by the dealer, it just gets me that it is so expensive to fix anything on the Jag including a turn signal light bulb!
Still, got to love the Jaguars!
Old Apr 5, 2008 | 12:31 PM
edra566's Avatar
I was thinking about replacing my back up light and rear turn signal lights with LED's, do you not recommend this because I may also damage the sensor?
Old Apr 6, 2008 | 09:53 AM
reddrawf's Avatar
Just be very careful removing the cover over the truck latch. I have no idea hw I damaged the sensor as I thought I was being careful!
Good luck and post pictures if you do it!
mbergen
Oct 23, 2019 10:26 PM
Richard_gib
Sep 12, 2015 07:08 PM
tonyforman
Sep 10, 2015 07:23 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
jaguarbill
Sep 5, 2015 11:43 AM
