Is V8 interference engine?
Old Feb 12, 2015 | 06:47 AM
car5car's Avatar
Default Is V8 interference engine?
If chain breaks, will valves break too? Thanks.
Old Feb 12, 2015 | 07:02 AM
Gippsland's Avatar
Usually YES. Also possibly pistons depending on speed (revs)
Old Feb 12, 2015 | 07:28 AM
JagV8's Avatar
However, reports of chains breaking seem to be close to zero on the 4.2. Avoid the 4.0 unless you're going to upgrade the known-inadequate parts.
Old Feb 12, 2015 | 09:56 AM
NBCat's Avatar
I have seen 4.0 litre engines that break the upper chain and escape having damage to the inlet valves. Once new chains and tensioners were installed, the engines started and ran normally, while others have not been as lucky.
To directly answer your question, the V8 engines are interference design.
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
