valve body spring
Old Sep 19, 2011 | 05:46 PM
megalosdog's Avatar
Default valve body spring
Hi, I just took down the valve body from my 2000 s type with 5r55n trans. A spring fell out as I was lowering it, from what I understand it is called the main spring. The problem is I can't figure out where it came from, there is a hole where it looks like it should go but I hate to put it back together and it be screwed up. I followed this link HERE and it warns about this but doesn't say where it goes..any help would be awesome, thanks
Old Sep 19, 2011 | 06:22 PM
See if these help,
http://www.sonnax.com/system/instruc...947J-S2-IN.pdf
http://www.sonnax.com/system/pdfs/11...pdf?1289926275
http://www.sonnax.com/downloads/valv...Ford-5R55N.pdf
Old Sep 19, 2011 | 08:13 PM
megalosdog's Avatar
these are great info but they dont say anything about the main sping between the valve body and the trans body..it's red and relatively large
Old Sep 22, 2011 | 10:19 AM
Maybe a picture would help?
Old Sep 22, 2011 | 08:38 PM
megalosdog's Avatar
got it..thanks
Old Sep 22, 2011 | 10:01 PM
H20boy's Avatar
I was just going to help ya with that. u didnt lose those 2 little ***** did ya?
Old Sep 23, 2011 | 05:56 AM
Good news.
So where did the spring go, in case someone else has the same problem?
Old Sep 24, 2011 | 08:34 AM
megalosdog's Avatar
No did'nt lose the ***** and there is actually 3 ***** in my valve body, 2 on the edge next to eachother and one kinda towards the middle. As for the main spring If you look up at the trans with the vb down there is a hole with some kind of brass fitting inside. It is the only place it could naturally go. It's towards the back by the big circular part called the low/reverse servo (i believe)
megalosdog's Avatar
xjrjag
Oct 24, 2024 03:09 PM
bamforp
Aug 14, 2024 05:36 PM
08Z06
Oct 24, 2015 05:46 PM
Tar
Sep 6, 2015 11:24 AM
Corycarlo
Sep 5, 2015 11:41 AM
