Vanity Mirror Cover Fix W/Pics FAQ
Old Mar 6, 2012 | 11:57 AM
joycesjag's Avatar
Default Vanity Mirror Cover Fix W/Pics FAQ
Difficulty Level: novice
Tools Needed: Drill, 7/64" drill bit, medium flat blade screwdriver, epoxy, 3/8" long heavy duty coat hanger or paint can handle, masking tape (optional)
Time: less than an hour
This procedure was done to a 2005 S Type. Others MYs should be similiar.
Start off with gently prying the vanity mirror off the sun visor. No need to remove sun visor from vehicle. In the following pictures notice that this is NOT a broken vanity cover (I replaced the drivers side cover with the passenger cover for aesthetics).
There are 2 tabs on the upper ("top") of vanity mirror and 3 on the lower portion. The yellow arrows will be explained in the end of this post.
Using the masking tape (optional) I measured 3/16" for depth of "new" flap pin on the 7/64" drill bit.
I just held the cover in my hand and used a 3/8 cordless drill to drill new hole.
Epoxy "new" 3/8" long pin in, wipe access off and let cure.
To help with the epoxy set, I placed cover in the sunlight which also made the cover pliable enough to slightly bend enough to slip cover plate into the vanity mirror assembly. The crack in the upper middle of the vanity assembly was already there prior to the "cover plate" fix.
**NOTE: When placing the vanity assembly back into the visor. MAKE SURE THE COVER IS IN OPEN POSITION for proper alignment of the light tab indicated by the yellow arrows. Place lower portion of assembly in first then locking the upper tabs into visor.
If you need to just change out a vanity light bulb. Gently pry out assembly from visor as shown to gain access to bulbs.
Old Mar 6, 2012 | 12:30 PM
Jon89's Avatar
Great job as always, Rick. I did this fix a couple of years ago to our drivers sun visor using a small finishing nail inserted and epoxied into the hole as my new pivot bar. A metal pivot bar instead of the lousy plastic one fixes this problem permanently....
Any update on the door lock tab rechroming job? I still have the small piece of metal foil tape wrapped around ours for protection from finger cuts. It doesn't look great, but it does the job....
Old Mar 6, 2012 | 01:05 PM
Great FAQ as always Rick , but, dare I say it.....
You're going to have to start videoing these fixes for the database...........These write ups with pics are so old hat j/k
Old Mar 6, 2012 | 06:42 PM
aholbro1's Avatar
Nice job, Rick. I need to perform that service on baby's 03 if it's ever around the house here long enough without some more major problem plagueing it.
Old Mar 6, 2012 | 06:59 PM
joycesjag's Avatar
Thanks for the thanks guys.
Zane take the easy way out just switch the 2, until you get the time. That only takes a minute !
Our broken one sat on my work bench for well lets say awhile........
Old Mar 6, 2012 | 07:31 PM
aholbro1's Avatar
Don't really recall..but I think her broken one is pax side...just have it clipped with an approach-plate clip right now, I think. There's a thought! could swap her's with momma's...even so they are different colors......
Old Mar 19, 2012 | 10:15 PM
jaguarastic's Avatar
hey guys, my vanity mirrors(both driver and passenger side) are missing the lids...this is how I got them when I bought the car, any place/site I can get either just the lids or the entire vanity mirror? I checked on eBay but they dont have any in the beige color
Old Mar 20, 2012 | 08:39 AM
RizwanSharp's Avatar
Thanks Rick for an awesome tutorial. My Passenger side is broken, I was planning to use Dowel Pins to fix it.
Amazon.com: Passivated 416 Stainless Steel Dowel Pin, 1/8" Diameter, 3/8" Length (Pack of 10): Industrial & Scientific
I was wondering if the one in the link above would be the correct length and diameter?
Thanks a lot.
Old Mar 26, 2013 | 09:24 PM
Eel's Avatar
Eel
Thanks a lot.
Do you know if those dowel dimensions will work to use for the visor mirror repair? Can anyone direct me where I can purchase replacement light bulbs that will be the correct size for the visor light bulbs? I've never done any kind of car repairs before, so I'm totally unfamiliar with websites where I can purchase Jag replacement parts & would greatly appreciate any suggestions?!? I also don't know how to figure out the exact dimensions of the visor vanity mirror light bulbs (besides the letters/numbers that are engraved on the metal part of the light bulbs)..can any provide this info?
Thanks in advance!
Old May 23, 2013 | 10:39 AM
CMS's Avatar
CMS
Are the mirror covers spring loaded to hold mirror from swinging or having to hold cover open manually?
Thanks,
CMS
Old May 23, 2013 | 10:49 AM
tbird6's Avatar
Yes there is a small piece of spring steel on the hinge. You can lose it when the plastic pin breaks too.
Anybody fix loose visor fabric? I had to replace my driver’s side visor because the material got very loose and baggy. I think the glue bond decayed from heat and time so the material started to pull away from the thin foam it's glued to.
Sad to say it was $231 from Jaguar. I have torn down the old one but it looks completely un-repairable as everything appears to be molded together as one piece. I had a difficult time splitting the visor and the material has to be folded a certain way when it's glued back together.
All the repair instructions I can find on the internet are for different kinds of visor construction than what the S Type has.
Old May 23, 2013 | 01:33 PM
Jon89's Avatar
Rather than purchase an entirely new visor, I would consider making a couple of new visors out of a thin sheet of light hardwood, perhaps three-eighths of an inch in thickness. A two-foot by two-foot panel would be plenty to make both visors. Use your existing visors as your templates. Stain them to match, and you've got a very unique and attractive addition to your car....
I don't think I would attempt to carry over the mirror lighting, though. Mirrors on the back sides, possibly, but not the lighting....
Old May 27, 2013 | 08:11 PM
CMS's Avatar
CMS
Tbird6,
Is there anyway to replace springs in the visors?
CMS
Old May 14, 2016 | 11:25 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Thanks a lot.
Old thread I know, but wondering if you tried those 1/8" x 3/8" stainless dowel pins for your visor fix and, if so, how did they work out? I'm about to do this fix on my '05 S-Type and these pins seem like a real time saver. Would like to hear your comments/suggestions. Thanks, Steve
Old May 16, 2016 | 04:13 PM
joycesjag's Avatar
Steve save your money. Cut a larger diameter coat hanger or a paint can handle will work just as well.
Old May 17, 2016 | 07:31 AM
Jon89's Avatar
I used a small finishing nail many years ago. Still works like a champ. The key is to use a strong epoxy to keep it in place....
Old May 17, 2016 | 01:12 PM
Thanks, Rick and Jon89. I live in a paint-free world containing only plastic hangers LOL. so I'm gonna try Jon89's finishing nail trick. Both great ideas.
And thanks again, Rick, for the great write up with pics. Truly invaluable! I had no idea how to solve this problem on my wife's S-Type until I read saw your fix. Made it look easy for a guy with all thumbs like me. Steve
Old Jun 14, 2016 | 09:19 PM
Default 1/8"x3/8" stainless dowel pins as vanity mirror lid hinge fix
To answer my own question… yes, the 1/8"x3/8" stainless steel dowel pins sold at Amazon are a real timesaver. With all due respect to JoycesJag and John89, I took the lazy route and bought the precut pins, which worked perfectly.
The pins come in a pack of 10 for $8 inc shipping and they're the exact size needed for this job. True, I now have 9 spare dowel pins, but I own 3 S-types and another of them looks like it will need this fix sometime soon, so I don't think they'll go to waste.
I scuffed up one end of the pin with sand paper before gluing it into the hole I drilled where the broken pin had been. And I used the same Devcon epoxy that Rick used, which works on both metal and plastic, sets up quickly and completely cures in 24 hours.
While I had the mirror frame out of the car, I also took the opportunity to repair the crack it had in the same location as Rick's pic #10. Crazy Glue worked great here - I held the frame while my helper dropped a dab of glue in the crack, then I simply squeezed real hard to close the seam for about 2 minutes and...Voila! Crack is fixed.
Many thanks again to JoycesJag for posting the tutorial for this fix, and to Jon89 for his suggestions too. And thanks to RizwanSharp for the original link to the dowel pins on Amazon, which as of this date is still active. Best 8 bucks I ever spent, as my wife is a happy camper again
Here's the link again -
1/8"x3/8" Stainless Dowell Pins 1/8"x3/8" Stainless Dowell Pins
If you're lazy like me, these 1/8"x3/8" stainless dowel pins, sold on Amazon, are a good but slightly more expensive alternative to the other DIY options mentioned in this thread if you need to fix a broken vanity mirror lid hinge.
Old Jun 15, 2016 | 07:35 AM
Jon89's Avatar
Well done. I always enjoy reading the various approaches that we all come up with to solve these nagging issues as they arise. So many of them involve the lousy plastics in our cars. Any time you can replace plastic with metal, you're one step ahead....
Old Jun 15, 2016 | 11:39 AM
I'm with you there, brother.
