Vavoline Full Synth Trans Fluid
Old May 17, 2017 | 08:22 AM
Sixx Dogg's Avatar
Default Vavoline Full Synth Trans Fluid
2006 stype 3.0
Good morning gang!
Time for my second change, not going to use lifeguard 6 rhis time. I was wondering since I can't find Mercon sp ..this one says it's a match for it on the back of the bottle.
Any advice?
Thank you as always
Sixx
Old May 17, 2017 | 08:39 AM
Mikey's Avatar
From further down this page:
https://www.jaguarforums.com/forum/s...models-181524/
Draw your own conclusions.
Old May 17, 2017 | 09:59 AM
Jon89's Avatar
All Ford dealerships here in the US carry Mercon SP. Is that not the case for Ford dealerships in Canada?
Old May 17, 2017 | 10:04 AM
Mikey's Avatar
My local Ford dealer has it.
Old May 26, 2017 | 05:22 PM
gm_jim's Avatar
Bought mine here at a good price. The caveat is that it's only available in case quantities.
https://www.ryderfleetproducts.com/m...p-p-w83-xt6qsp
Old May 31, 2017 | 06:28 AM
DougB's Avatar
I'm wondering where you are getting the tranny cover from. I'm in the process of doing a flush of the ATF of a 2007 S & the filter and gasket are part of the tranny cover but Jaq Canada are quoting a very high price for the replacement (plastic) cover.
I'm told you can get the Mercon through Ford.
Old May 31, 2017 | 06:47 AM
JagV8's Avatar
Klaus will have pretty much anything you might want Genuine ZF Parts
Old May 31, 2017 | 08:07 AM
Six Rotors's Avatar
You can also try a BMW dealer or parts supplier---a number of their cars used the 6HP26 6spd auto transmission.
Old May 31, 2017 | 11:30 AM
joycesjag's Avatar
For what the ZF liquid gold? As mentioned many times, you cannot beat the Mercon SP as an less expensive alternative!
I personally many years back changed oring and filter. I used Castrol multi import vehicle ATF that matched the shell spec. of the liquid gold ZF. Castrol must have changed their formula, it is no longer meeting the shell spec. I will be doing a drain and fill on Joyces Jag in the near future. I wiil use the Mercon SP!
Old May 31, 2017 | 11:39 AM
JagV8's Avatar
I think he meant for parts other than oil.
Though I'd contact Klaus - if I didn't live over here...
(Here, I'd consider www.bristoltransmissions.co.uk)
Old May 31, 2017 | 12:00 PM
Mikey's Avatar
Don't know of any source here for the cover and sleeve. I'd just order them from Klaus as suggested.
Old May 31, 2017 | 12:10 PM
joycesjag's Avatar
+1 Klaus is da' man
Old Jun 1, 2017 | 11:55 PM
abonano's Avatar
Originally Posted by joycesjag
+1 Klaus is da' man
+2
Old Jun 3, 2017 | 11:30 PM
DougB's Avatar
Thanks all re: "Klaus"
