Weld the leeper...
Old Sep 8, 2007 | 07:27 AM
Bacardi 151's Avatar
Default Weld the leeper...
This has peeked my interest...
Anyone know if you can just weld underneath the hood? Which makes stealing the leeper without a plasma cutter near impossible.
Old Sep 8, 2007 | 11:33 AM
jag_genius's Avatar
Default RE: Weld the leeper...
i actually weld the leaper to the base... and sometimes i put a metal nut... actually welding the cat to the hood would a big job..
Old Sep 8, 2007 | 04:44 PM
I just have to look at it...I was thinking to weld it to the underside of the base. Not sure if that's an option, maybe even putting a coat of JB weld between the leeper bottom and base top would ward off pre-puberty teens and non-weightlifters... lol
Old Sep 14, 2007 | 07:48 PM
Ok, a little under $10, I made the leeper extremely hard to steal...
The bolt is just held on by a platic nut. If you want to replace with a metal bolt, the size is M16. In either Home depot or Lowes, the larger metic bolts including this oneis located in a drawer in the hardware aisle. You'll also need a DEEP socket. I happened to already have a 15/16, which will work but is not the exact size. The exact size is metric and I don't what it is, I do know it's larger than my largest socket of 22mm. A socket should be only$5 from walmart/auto or home store. I bought for $1.97 5min epoxy, I put it inside and around the exposed spring of the leeper. Once you remove the leeper, you'll see what I'm talking about. I've rendered the spring useless. I installed everything and pulled with all my might, nothing moves!
boiler
US Southwest
Dec 20, 2025 12:38 AM
Woznaldo
Sep 26, 2015 11:02 AM
hoodun
Sep 23, 2015 12:17 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
