well, i removed the EPB completely:
Old Apr 18, 2011 | 06:08 PM
phd12volt's Avatar
Default well, i removed the EPB completely:
disconnected all the lines, took it out of the car. So it was as i suspected. The gear inside is trashed. Electrically it works fine.
what a pain in the rear to get it out. it took about an hour just to disconnect the whle thing and get it out. i took the gearbox apart, and the stepper gear ( 2 gears on one shaft) is the one that is gone. It was pretty easy to see where the failure occured. ill take pics later on and show the point of failure.
Old Apr 19, 2011 | 10:26 AM
Scaaty's Avatar
phd12volt.....there was a recall for the EPB's on our model Jags. See link below:
PARKING BRAKE Recall for 2003 S-TYPE JAGUAR Auto Recalls - Justia Car & Truck Recalls
Hope this helps.
Old Apr 19, 2011 | 11:38 AM
Brutal's Avatar
Originally Posted by scaaty
phd12volt.....there was a recall for the epb's on our model jags. See link below:
parking brake recall for 2003 s-type jaguar auto recalls - justia car & truck recalls
hope this helps.
that applied to the module, not the actuator(motor assembly)
Jason per our pm's why dont you also put the word out for a bad used 1 that motor failed on and not the gearing and swap parts...just a thought+
If I had 1 Ide send it to you
Old Apr 19, 2011 | 01:04 PM
androulakis's Avatar
Gears | buy gears | spur gears
I can draw it up in Cad for you. Just need the specs.
Take care,
George
Old Apr 19, 2011 | 01:46 PM
Scaaty's Avatar
Brutal.....my bad! What do I know? My wife asks me that all the time LOL
Old Apr 19, 2011 | 09:01 PM
phd12volt's Avatar
scatty, thanks for the heads up, but i think my module was done already. it says revision A on it. And yeah i know about that recall, but it always a good idea to keep it in mind, so thank you for that.
Brutal great idea, ill search around locally and see if i can find one. I dont know the price i got from nalley was pretty good i think. Helluva quick response from them. And the pricing was less than i thought it would be.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
mrsimpson
Sep 15, 2015 01:10 PM
SeanU
Sep 14, 2015 04:31 PM
doctordeuce
Sep 12, 2015 08:30 AM
