What annoys you most about your S-Type??
Old Jan 11, 2011 | 01:52 PM
  #241
Pushing_Tin's Avatar
Thanks Rick! I'm trying to decipher this... I'd like to be rid of this annoyance, but don't want to spend a fortune. I wonder what it would cost to just replace the bushing first, and if that would solve the problem.
Old Jan 12, 2011 | 07:27 AM
  #242
SCMike's Avatar
A key distinction is if the "whine" is a constant condition at some speed (in which case the bushing replacement TSB might be relevant), or if the noise comes and goes in synch with your tipping in/out of the throttle pedal (which would suggest an issue with the pinion gear). If the latter (which is what I had in my '08), replacing the diff is the solution (esp. if still under warranty) - or getting into the diff guts and doing a rebuild. For example, see:
http://bernardembden.com/xjs/diff/index.htm
Old Jan 13, 2011 | 01:40 AM
  #243
Does anybody know whether the carrier bushings can be replaced w/o removing the entire suspension sub-frame to press them out?
My whine is only when lightly on the throttle, not constant at all.
Old Jan 13, 2011 | 09:06 AM
  #244
55chevy's Avatar
I got a left tail light fail, went to replace it and it was working. Then one morning I got both tail light fails, the car was crying wolf again.
Old Jan 13, 2011 | 09:36 AM
  #245
Jon89's Avatar
I've had that happen as well. The left taillight bulb was loose in its socket. I removed the bulb, cleaned its base as well as the interior of the socket, and carefully reseated the bulb. That was in early September 2009. No problem with it since....
Old Jan 13, 2011 | 09:46 AM
  #246
androulakis's Avatar
Yeah, you might want to take a needlenose pliers and slightly bend the metal tabs inwards if it continues to happen.
When I got my car it had one tail light brighter than the other. For a while I didn't even know... Someone told me.
So I pull the left (brighter) tail light out, and wouldn't you know, someone had jammed an 1156 bulb into the european p21y socket. That was a treat to take out.
Afterwards, I had the problem of the loose bulb working intermitently, so i had to sligjhtly the tabs back...
Take care,
George
Old Jan 13, 2011 | 03:21 PM
  #247
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
I wish the sun visors had the extensions in them that pull out to add extra blockage for driving into the sun. My wife's '08 Nissan Altima has them and they are great when they're needed.
On a recent trip to Visalia, driving south on hiway 99 (Central Calif)coming back home at daybreak, the sun was brutal shining in my eyes. The sun was peaking thru the Oleander bushes lining the center divider and was like a strobe light against my eyes. The extensions were a life saver which is why we take her car on trips and not the Jag.
Old Jan 13, 2011 | 03:35 PM
  #248
FireMedicJ's Avatar
Default ughhhh
PO795 stupid soleniod c!
trying to figure out what to do and how to do it!
and my dashboard the plastic part cracked :/ other wise never had a problem! oh i do have a slight oil leak but easy fix.
Old Jan 14, 2011 | 04:47 PM
  #249
55chevy's Avatar
My 55 Chevy had those visors, and my 91 Buick Reatta had extensions on the visor that pulled out. You'd think it would be a standard accessory by 2000.
Old Jan 15, 2011 | 03:01 PM
  #250
Originally Posted by androulakis
Here's a pic.. this is from a 2008 S-Type listed on ebay, but you get the idea relative to our cupholders. I'm sure someone on here has this cupholder and can give us actual dimensions.
Take care,
George
Got my new cup holder from Nalley yesterday, fits perfectly and I don't have to hold my mug between my legs now! Thanks George!
Old Jan 15, 2011 | 10:01 PM
  #251
ttwotees's Avatar
Originally Posted by Staatsof
It's not an issue all that much anymore since I had the auto lock doors "feature" disabled but the lack of a lock/unlock switch except for the one near the door handle. I'd like it on the drivers & passengers arm rest. The one on the dash in the center bin is not the same thing. That's a cycling button. So If you have just have the drivers door unlocked you have to first lock all doors then open all doors. You need two buttons or a rocker switch. Just dumb.
I agree about the windshield wiper area design. I also like to lift the wipers off the windshield and leave them up in the air when we get snow/sleet/ice. But hey, it's a part of the aerodynamic design of the car ...
Breaking HID headlamps that don't get a factory upgrade. I'm waiting for my second to be installed after next week. That's two broken in 5K miles on a car with 14.5K miles. After this I guess I'll be fixing it like everyone else out of warranty.
But these aren't deal breakers guys.
I was fortunate enough to buy an '04 STR with a 6yr/100K select edition warranty. At about 52K miles both of my headlights went south pointing down at the road, but
they replaced them with brand new HIDs under the warranty. The service guy said they cost over $1,000.00 each..
Old Jan 15, 2011 | 10:29 PM
  #252
55chevy's Avatar
OK, a gripe I haven't seen, I'm driving along at 55-65, steady speed, speed limit goes up, I step on the accelerator, nothing happens. It seems like I press it down about an inch or more before it finally increases the rpms and speeds up. My pedal doubles as a foot rest I guess.
Old Jan 15, 2011 | 10:39 PM
  #253
Welcome to the world of drive by wire cars.
Mercedes are worse, you almost have to pretend that the first half of the pedal travel doesn't exist.
What's even funnier is some cars, full throttle is only full throttle if it decides it's not going to spin the tires or something based on road speed and current gear.
A lot of the 'chip' tuning out there involves remapping how quickly the throttle opens based on pedal input. In essence the car "feels" a lot faster. But in reality you're just pressing the pedal more without realizing it.
Take care,
George
Old Jan 16, 2011 | 12:04 AM
  #254
ChrisSTR's Avatar
Use the J-gate. A quick flip to 5 and she's out of overdrive.
Old Jan 16, 2011 | 09:14 AM
  #255
Jon89's Avatar
That's one reason I still love my Ram pickup so much. An honest-to-goodness cable there, no drive-by-wire in that puppy. Ah, those were the days....
Old Jan 16, 2011 | 10:59 AM
  #256
Staatsof's Avatar
Default get some Webers!
Hey Guys, there's no substitute for the sound and feel of a V12 with a set of 6 DCOE Webers on it! Of course, setting the linkage up is a bitch but OH what a sound! No stinking ECUs either.
On the other hand, I got a drive in a 2011 Gallardo spyder last night. What a fantastic ride blasting down the Great Highway along the ocean in SF. I wouldn't last a day in this car before I went to jail.
Bob S.
Take care,
George
Old Jan 16, 2011 | 05:00 PM
  #257
bens's Avatar
They say that the line between Love & Hate is thin, well I love my S 4.2 V8, I loved my X type 2.5, just moved on, yes its got faults what car has not, live with it or get rid!
Steve
Old Jan 25, 2011 | 08:06 PM
  #258
TenPercenter's Avatar
Two things: The driver's sun visor doesn't extend, so only covers half my side window when the sun is on my left.
The other is that I wish it had a built-in compass.
Old Jan 26, 2011 | 01:46 AM
  #259
JagV8's Avatar
I believe many of the cars DO have a compass.
Out of curiosity: why do you want one?
Old Jan 26, 2011 | 08:22 AM
  #260
I'd think the answer is obvious but I'll give it a shot: So I know which direction I'm going.
To expand: I have a bad sense of direction, and was elated the first time I had a compass built into my car. When I didnt have one I'd buy one of those battery operated ones but they were always inaccurate because of metal in the cab etc.
My sense of direction is so bad that I can go into a place after parking, and when I come out I have no idea from which direction I came or which direction I need to go. I an visualize looking down on a map and know the direction I need to go, but then I need a compass.
