Where can i get a expansion tank
Old Jan 19, 2016 | 08:15 PM
Jason Souhrada's Avatar
Default Where can i get a expansion tank
I know there's some on eBay for $150. But I'm wondering where you Jag veterans can tell me where to get a new one for less. Mines the 4.2 STR
Old Jan 19, 2016 | 08:59 PM
aholbro1's Avatar
$150 not too bad for the "R" apparently. It's in here somewhere: https://www.jaguarforums.com/forum/s...-again-144224/
Old Jan 19, 2016 | 10:41 PM
Warspite's Avatar
Try Craigslist close to you, under "auto parts." "R" models are uncommon, however plenty of standard examples are around. I don't know if the "R" ones are interchangeable with the normally aspirated ones.
Good luck in your search.
Old Jan 20, 2016 | 08:50 AM
tbird6's Avatar
Get it. That price is good.
Do not even consider used. This is a plastic tank that will fail 100% given enough time. It's just a wear part.
Old Jan 20, 2016 | 09:33 AM
davidladewig's Avatar
I can tell you from experience to get the best, most expensive tank you can order. The cheap ones will break early and if the lot is bad from China, you will be doing this job a lot. If you find a tank with a manufacturers number REPJ161308, RUN BUBBA RUN. I had two crack in the same place in 5 months. On my third tank and hope this one is from a different lot.
Amazon has them. About 150 each for the good one. Overheating an aluminum part is death to the part in most cases. While you have it out of service, change all the antifreeze. Use the factory numbers to match. Fill it, bleed it, and ride.
Old Jan 20, 2016 | 09:39 AM
Is there a thread on the drain, fill and bleeding
Old Jan 20, 2016 | 10:50 AM
JagV8's Avatar
Several. Search / Advanced Search for them.
Wayne1357
Sep 25, 2018 02:31 AM
01Silverstone
Feb 19, 2016 07:37 PM
anthawk
Jan 15, 2016 03:45 PM
XKR_100
Jan 14, 2016 06:04 AM
Stamford
Jan 13, 2016 08:25 PM
