White stuff
Old Aug 27, 2013 | 03:21 PM
Bigblackcat's Avatar
Question
More problems with my s type car holding back when you put your foot down starts first time no smoke but now I've got white stuff on dip stick and oil cap not over heating need help need to know if head gasket as gone (hope not)I've replaced timming chain and all tensions
My car is a 4 litre v8 1999 108000 miles on the clock full service history
I'm the one with the white stuff problem on oil cap and dip stick
Old Aug 27, 2013 | 03:25 PM
thebiglad's Avatar
If it looks like mayonnaise, that's a classic sign of blown head gasket.
Old Aug 27, 2013 | 06:03 PM
JagV8's Avatar
which engine? mileage? etc
Old Aug 27, 2013 | 07:23 PM
Bad Cattitude's Avatar
Engine compression test / coolant system pressure test should tell you how the water is getting into the oil.
Old Aug 28, 2013 | 04:45 AM
The white 'stuff' might be nothing at all.
Simple condensation can form allowing the creation of some mayonnaise in the oil cap and dipstick. Depending on climate and engine temp conditions.
@ John, check post #1 ^ I have merged the info into it.
Old Aug 28, 2013 | 07:03 AM
Michael Star's Avatar
How far do you drive everyday?
Old Aug 28, 2013 | 07:46 AM
JagV8's Avatar
Don't panic - yet! As above, it may just be short trips. Tell us more.
Old Aug 28, 2013 | 10:53 AM
speedwaymike's Avatar
Before I sold my XJ6 I had the same issue. Turned out the dipstick tube had come loose at the bottom, letting in moisture. Simple Fix...
Old Aug 29, 2013 | 05:09 AM
Hi I drive maybe one mile on average during the week and maybe eight miles at the weekend . Again many thanks for your help
Old Aug 29, 2013 | 05:26 AM
JagV8's Avatar
Aha! What happens is that moisture is a result of burning fuel - it's a hydrocarbon so the overall idea is the HC changes to H2O (water) and CO2. A long trip gets everything so hot that most H2O goes out of the exhaust. Short ones and some mixes with the oil and creates what's known as mayonnaise (not that kind!). Definitely don't panic. Some longer trips would be good for the car but at least change the oil more often (to get rid of the nasty stuff - it's not a good lubricant at all).
With such short trips you may also flatten your battery as it may be too short to recharge from the loss at starting.
Poet
Feb 7, 2025 02:18 PM
aode06
Jul 28, 2023 02:26 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
Msteiner
Oct 1, 2015 01:18 AM
ziondio
Sep 29, 2015 01:58 PM
