The wonderful limp mode today.
Old Feb 26, 2011 | 03:09 PM
fergs03R's Avatar
Default The wonderful limp mode today.
so we got a couple inches of smow, car was in the driveway, did not drive for a day and went to clear off snow which was melting. There was plenty left between the hood and windshied(bad decision) and my wife left and drove 5 miles and parked.When she came back 4-5 hrs later....limp mode....
This scenario really lends itself to the throttle body connector moisture issue dont you agree?
I picked her up but before hand I disconnected the negtive battery(just in case it resets) cable... now im heading back with a blow dryer...hope its as simple as that!!
Old Feb 26, 2011 | 03:56 PM
Iluvmy05STR's Avatar
Moisture + TPS = Limp Mode I've been there, done that.
I don't know if I'd try to dry it out with a blow dryer. It may do more harm than good.
As far as keeping moisture out; loosen up the plastic cowl under the windshield and run a bead of silicon between the cowl and the windshield. Also make sure all the screws holding the cowl in place are water tight.
Old Feb 26, 2011 | 04:24 PM
fergs03R's Avatar
so I brought my obd2 scanner with me...code as expected came up as a TPS code...cleared code and all is good..but yes, I wi l be doing some maintenance on the moisture issue...
another case for having your own scanner..... took me all of 2 minutes to resolve issue...for now
Old Feb 26, 2011 | 04:33 PM
androulakis's Avatar
Glad you got it resolved. Would you be willing to add your name to the list of members with scanners who would be willing to scan other member's cars for them?
See here:
https://www.jaguarforums.com/forum/s...787#post311787
Take care,
George
Old Feb 26, 2011 | 05:01 PM
Jagoff's Avatar
heres a link to the how to fix this problem write up i just posted.
https://www.jaguarforums.com/forum/s...ad.php?t=50510
i hope it helps
Old Feb 26, 2011 | 06:08 PM
fergs03R's Avatar
See here:
Take care,
George
hey george...I am added!
Forcedair1
Sep 8, 2025 01:57 PM
tomsjag
Jun 10, 2023 10:02 AM
Forcedair1
Feb 19, 2020 01:51 PM
cissdm
May 3, 2016 06:02 AM
Phil G.
Sep 12, 2015 07:42 AM
