Won't start
Old Jan 1, 2013 | 09:10 PM
dthompson7's Avatar
Unhappy Won't start
2004 S-Type 3.0
Problem: When I go to start the car I get a beeping sound inside the car. All gages peg out then return ot normal setting. When turn the switch to ON, the car won't start or make a sound like if it want to start. Help please!
Old Jan 1, 2013 | 09:55 PM
cbharley10's Avatar
Sounds like a possible issue with the immobilizer... Do you have more than one set of keys by chance? I would start with trying a different key if possible, it may be as simple as the key out of sync with the computer and the immoblizer is kicking in to prevent the car from starting...
Old Jan 2, 2013 | 02:00 AM
JagV8's Avatar
Could be a failing battery. The gauges strongly point to this.
Also could be gear shifter out of alignment so not really in P even though it seems it is. Might try N.
Old Jan 2, 2013 | 06:38 AM
dthompson7's Avatar
the battery is good had check out
Old Jan 2, 2013 | 06:41 AM
dthompson7's Avatar
only have one key. How can the immobbilizer be reset?
Old Jan 2, 2013 | 07:31 AM
Gus's Avatar
Gus
Have you tried to start it in “N”?
Old Jan 2, 2013 | 08:12 AM
JagV8's Avatar
How? Seriously. You need a storage 'scope to do this right nowadays due to the computers. Must maintain lots of volts during hard cranking. Yours sounds so poor it doesn't even crank. Did you try N as I (& now Gus) suggested?
Old Jan 2, 2013 | 08:52 AM
dthompson7's Avatar
Yes, try starting car in N. Still same results, Won't start
Old Jan 2, 2013 | 03:47 PM
tbird6's Avatar
You are not listening to what the guys are saying??
How old is your battery? Not that it has been tested. We can go no farther until we know this. As JagV8 said we have a clue since the gauges peg out and then come back down but that is only a clue.
Don't live with only one key. It will bite you. Get the proper key and FOB as a backup.
Old Jan 2, 2013 | 05:04 PM
dthompson7's Avatar
the battery is the orginal. The car is a 2004
Old Jan 2, 2013 | 05:26 PM
joycesjag's Avatar
dthompson, we don't tolerate that.
warned
Old Jan 2, 2013 | 06:02 PM
JagV8's Avatar
It's done really well to last so long but realistically is by far #1 suspect and quite a cheap thing to replace compared to most other suspects. Not THAT cheap as you need to buy a hefty one of the right type. Have a Search to see what others have been recommended recently.
Old Jan 2, 2013 | 06:51 PM
devo357's Avatar
No experience with this on my Jag BUT I have had this happen on 2 different cars and a motorcycle same symptoms. Get a good load test just because its showing good voltage doesnt mean its good. My 2 cents
Old Jan 2, 2013 | 07:34 PM
GT42R's Avatar
Bad battery!
I had similar symptoms, and turned out to be the battery after all.
Old Jan 2, 2013 | 07:35 PM
dthompson7's Avatar
Thumbs up
Thanks to all reply. I bought a new battery the car started fine. Once again, Thank you very much
Old Jan 2, 2013 | 07:39 PM
bfsgross's Avatar
Way to go dtthompson! Awesome help guys.
dsnyder586
Dec 29, 2024 07:39 PM
JarodL
Mar 7, 2024 01:39 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
