x-reference for 02 sensors?? 03 str
Old May 3, 2011 | 07:52 AM
phd12volt's Avatar
Default x-reference for 02 sensors?? 03 str
any chance there is a cross reference for the STR 02 sensors?? to the ford/lincoln??
Old May 3, 2011 | 08:04 AM
JagV8's Avatar
Care if they have the right plug on them?
Also, fronts or rears or both?
Old May 3, 2011 | 08:08 AM
phd12volt's Avatar
hmmmm no i can change plugs.
DRIVER SIDE UPSTREAM 02 SENSOR
Old May 3, 2011 | 03:29 PM
phd12volt's Avatar
On a whim I checked at Napa and they have it for 109. Anyone ever done those?
Old May 3, 2011 | 03:37 PM
vance580's Avatar
I haven't done them on the R but on other cars. The hardest part is getting them off. Use lots of PB blaster on it and just let it sit and work its magic. There is a special socket you can rent that will allow you to use a socket wrench with a breaker bar which also helps alot. Usually autozone or Advanced will rent the socket.
Old May 3, 2011 | 06:20 PM
JagV8's Avatar
Yeah, they can be in TIGHT
Old May 3, 2011 | 06:58 PM
achysklic's Avatar
I used this wrench, it made my o2 sensors come out like butter! mine had 100,000 miles on them and I didn't even have to use any lubricant on them.
Amazon.com: Neiko Tools O2 Oxygen Sensor Flex Head Wrench: Home Improvement
Old May 3, 2011 | 07:51 PM
vance580's Avatar
Nice wrench achysklic. That would definitly make the job easier.
Old May 4, 2011 | 12:43 AM
JagV8's Avatar
Cool tool!
Old May 4, 2011 | 08:52 PM
phd12volt's Avatar
well, i contacted Dan at Nalley, and it is 11 dollars difference for the factory one. Buying it through Napa isnt worth the 11 dollars difference for me. Once again Nalley proves its worth to the forum.
Old May 5, 2011 | 03:07 AM
Cadillac's Avatar
Thanks for your feedback , Dan is getting 100% feedback too . They always perform a good job
Old May 5, 2011 | 08:08 AM
EZrider800's Avatar
Just out of curiosity how much were they from nalley? There are four of them!!! I just turned 100K on my S-Type and figured it was about time to do plugs and belts and hoses and O2 sensors............right?
Old May 6, 2011 | 08:28 AM
JagV8's Avatar
Caution: there are 2 types (fronts & rears) and they likely have diff prices.
Poet
Feb 7, 2025 02:18 PM
carl purchase
Oct 14, 2015 06:14 PM
Dave1109971
Sep 30, 2015 11:04 PM
leep123
Sep 30, 2015 03:41 PM
SoCalJagS
Sep 27, 2015 09:20 AM
