Xenon HiD Lowbeam headlight not working
Old Feb 3, 2024 | 01:47 PM
AuntMei's Avatar
Default Xenon HiD Lowbeam headlight not working
Passenger side low beam. Bulb, Ballast, igniter, fuses have all been changed. Any suggestions on what to do after this? Not working.
Ballast, igniter, bulb replaced.
Passenger side xenon low beam not working randomly went out. Swapped parts and got new ballast etc. thinking it may be wiring?
Old Feb 3, 2024 | 06:18 PM
xalty's Avatar
GEM or the non servicable relays in the front junction box.
both of my cars do this. flick the switch again and the right hid relay kicks on. never cared enough to look for ground at the GEM when it happens
Old Feb 3, 2024 | 07:00 PM
AuntMei's Avatar
i’m sorry but i’m not understanding what you mean by this?
suggesting to check the fuses in the junction box? Also what is GEM mean?
Old Feb 3, 2024 | 07:07 PM
xalty's Avatar
General Electric Control Module, sometimes called the FEM
light stalk position fed to the gem. gem grounds hid relays that are in the front power distribution box
Old Feb 3, 2024 | 07:13 PM
AuntMei's Avatar
F14 was replaced with a new 15A fuse. Same for the driver side.
However, F9 has not been replaced. Is this the fuse box you are suggesting?
I apologize in advanced this is all very new to me.
Old Feb 3, 2024 | 07:31 PM
xalty's Avatar
my bad i was mistaking it with the x350’s power box.
the stype has a serviceable relay in there. r13 look for power and ground on the coil side
Old Feb 3, 2024 | 07:51 PM
AuntMei's Avatar
truthfully, I have no idea what I’m looking at here. Is this in the front fuse box? Or is this part of the wiring?
R13 on the front fuse box can just be flipped?
Old Feb 3, 2024 | 08:00 PM
AuntMei's Avatar
Found another post from earlier in time with the same issue. This may have helped. It’s funny you were there too. Thanks for the help! Will try this and then update in the future.
bobhoff
Jun 21, 2023 06:20 PM
silversurfer1221
Oct 7, 2021 02:02 PM
XJRPro
Sep 23, 2012 09:39 PM
kirk whitaker
Dec 25, 2010 09:32 AM
Xx_Four_Stroke_xX
Sep 12, 2010 08:03 PM
