Are you supposed to replace PCV valve on the 4.2 V8?
Old Aug 27, 2025 | 04:00 PM
Catmobile's Avatar
Default Are you supposed to replace PCV valve on the 4.2 V8?
Are you supposed to replace the PCV Valve on a 2003 Jaguar S Type with the 4.2 NA engine? I don't believe that mine ever has. No trouble codes or anything, I'm just wondering. It has the large plastic disk shaped valve, not the metal tube kind. If it should be replaced every 20 years or so, does it just pull out of the valve cover after other things are removed or is there a keeper down under it? Any feedback would be good.
I'm sorry for posting similar threads on the same thing before. I got a notice saying it didn't work. How do you delete a thread or post when you make a mistake? Thanks
Old Aug 30, 2025 | 02:57 PM
Catmobile's Avatar
I talked to a Jaguar tech and he told me that there should be suction when you take off the oil fill cap when the engine is warm and running if the pcv valve is working right. You should be able to feel it with your hand or if you stretch a rag over the hole it will draw it in. Probably the same thing for most cars.
scrannel
May 18, 2024 09:01 PM
sidescrollin
May 9, 2018 07:47 AM
pagodino
Aug 31, 2014 06:29 PM
Spurlee
Mar 7, 2011 03:02 PM
Oldengineer
Apr 11, 2009 03:48 PM
