ZF Transmission Adaptions Drive Cycle clutch A problems, picture
Old Apr 7, 2013 | 09:19 PM
03Xtype's Avatar
Default ZF Transmission Adaptions Drive Cycle clutch A problems, picture
I was able to adapt every clutch except for clutch A. My guess is that maybe it wont set because of my trans problem ( code P0735 ). But maybe I'm doing some thing wrong, any pointers on Clutch A adaption? This is the info I have for the procedure:
11. 'A' Clutch
^ Maintaining constant throttle input and the torque band is within the indicated bar graph range, continue accelerating to 50 mph (80kph), ensuring the transmission upshifts into fifth gear.
^ Lift off the throttle, allowing the vehicle to slow down until fourth gear engages. The next vacant box for 'A' clutch will turn green with a 'tick'.
Attached Thumbnails ZF Transmission Adaptions Drive Cycle clutch A problems, picture-img_0402_zps124cfb8b.jpg
Old Apr 9, 2013 | 01:18 AM
03Xtype's Avatar
for a Jag Tech
Old Apr 9, 2013 | 10:44 AM
JagV8's Avatar
I'm not clear how P0735 would interfere with adapting clutch A but some details of P0735 for Ford's use of ZF 6HP26 (probably applies to Jag too) is publicly accessible here http://www.motorcraftservice.com/vdi...f/obdsm505.pdf
Old Apr 10, 2013 | 12:07 AM
03Xtype's Avatar
I some how was able to get 1 tick on the Clutch A adaption, so I guess it is just a matter of time.
BrentGardner
29
Dec 16, 2024 12:13 AM
Jandreu
Aug 23, 2019 11:37 AM
johanasu
Sep 3, 2015 12:39 PM
Newsguy
Aug 30, 2015 11:27 AM
Jandreu
Aug 29, 2015 07:31 PM
