Zf6 diy rebuild
Old Mar 7, 2017 | 12:18 AM
simmo616's Avatar
Default Zf6 diy rebuild
Has anyone reconditioned their own zf6? I did a search but couldn't find anything.
Old Mar 7, 2017 | 06:07 AM
joycesjag's Avatar
Genuine ZF Parts
Old Mar 7, 2017 | 06:33 AM
simmo616's Avatar
Awesome. Thank you.
Old Mar 7, 2017 | 07:53 AM
pab's Avatar
pab
>Genuine ZF Parts
Yup, that's what you need. But make sure to read up on the procedure it's kind of yucky (e.g., you fill the tranny from underneath, using a pump, while the engine is running at normal temp, with the exhaust down pipe REAL close... ;-).
You dreamed of a big star -
He played a mean guitar -
He loved to drive his Jaguar...
So welcome to the machine
Old Mar 7, 2017 | 08:27 AM
aholbro1's Avatar
More hints:
Make sure you can loosen the fill plug BEFORE you drop the pan.
Crack all the pan-bolts loose before fully removing them - so you'll know the ones that are prone to strip-out or break off before you proceed and can have the proper replacements on hand.
Also, best to figure out your refill-solution before the restart, while everything is still cool and touchable. You will need some sort of tubing arrangement, possibly with a 90 deg connection.
You may also need to cut down an Allen wrench to fit the fill-plug and clear the exhaust - many are too long.
Disclaimer - I've never done this - took both mine to Motorcarman!!!
Old Mar 7, 2017 | 10:49 AM
joycesjag's Avatar
I dislike you Zane
Old Mar 7, 2017 | 12:39 PM
abgusaf's Avatar
There are alot of videos on youtube of people pulling the valve body and changing out the solenoids, which can found on the ZF website, or even ebay. There are a few companies that sell reconditioned valve bodies ready to go. Ie. Revmaxx
From everything i have read, its a pretty solid transission, other than valve body problems.
But search the actual transmission in google. "ZF6HP26". They're used in a bunch of other vehicles other than jag.
Old Mar 7, 2017 | 12:46 PM
Ducmon's Avatar
If you go to this thread you can get the factory manuals as pdf
http://www.jaguarforum.com/showthrea...hlight=Zf6hp26.
Good luck
Old Mar 7, 2017 | 01:01 PM
simmo616's Avatar
I'm not just doing a flip change. I'm going overhaul the whole box. Just hoping to find an iaw and ipc.
Old Mar 7, 2017 | 01:40 PM
Ducmon's Avatar
The instructions from the factory for dealers is my last post on how to refurbish
Old Mar 7, 2017 | 01:52 PM
simmo616's Avatar
Ducmon: yep got that. Thanks buddy.
Old Mar 7, 2017 | 02:12 PM
Donna's Avatar
If I can do it, anyone can... My only advice - be careful torqueing down the new bolts. The manual says torque to 10NM but they will shear off at 10.0001NM. And trust me, trying to drill out a steel bolt in an plastic pan and an aluminium transmission case with only just enough room for the drill laying on your back with the car precariously balanced on four axle stands is not my definition of a wonderful weekend!
Old Mar 7, 2017 | 02:18 PM
simmo616's Avatar
No problem. All my tq wrenches are calibrated to aviation standards I'm used to drilling out seized screws in aircraft so that side of disassembly and reassembly doesn't bother me so much. Just want to recondition the box while it's convenient for me rather than it giving out on the side of the road.
Old Mar 7, 2017 | 06:38 PM
gm_jim's Avatar
ZF 6HP26 Teardown
