V6 to V8 swap possible?
Old 06-22-2017, 05:41 PM
Dan's cat's Avatar
Default V6 to V8 swap possible?
I wouldn't be asking if I didn't have to replace/ repair my current V6 engine to the tune of the possibility of entertaining the swap. I am just wondering if anyone has looked into doing this before. I didn't see anyting in search.
I would imagine the bell housing of the tranny, motor mounts and exhaust manifolds for sure, but what else to get the V8 to fit in the V6 space?
Please forego all of the snide comments as it is a hard enough pill to swallow to have to fork over this much money. I'm just looking for some help in the form of guidance and advice.
Very much appreciated, guys.
Old 06-22-2017, 05:55 PM
Mueller's Avatar
How are you not still under warranty to where this shouldn't be a question?
Old 06-22-2017, 06:05 PM
Dan's cat's Avatar
No, unfortunately.. ugh
Old 06-22-2017, 06:26 PM
Mark G's Avatar
Anything is possible, but it would be prohibitively expensive and a major pain. And you wouldn't gain any value as the car would be a Frankenstein. You'd be much better off selling your current car without an engine and then buying an R.
Jagged Wire (06-23-2017)
Old 06-22-2017, 06:46 PM
SinF's Avatar
Sorry to hear about your engine, what happened?
Old 06-22-2017, 06:47 PM
Dan's cat's Avatar
Well, I'm looking at $10-15k right now as it is, so I'm entertaining the option.
I'm not trying to increase the value, but that being said, I would hope that it wouldn't decrease it either.
I wouldn't have any idea what I could get for it without an engine. lol It has all the packs. It was originally sold for $99k and currently has 34k miles.
Old 06-22-2017, 06:52 PM
Fitting the engine mechanically would be a piece of cake. Teaching the rest of the car that it now has a V8 instead of the expected V6 would cost more than the value of the replacement engine and car together.
Dan's cat (06-22-2017)
Old 06-22-2017, 07:01 PM
Received 4,436 Likes on 2,421 Posts
Sorry to hear about that.
You can take a 3.0L s/c V6 engine from any Jaguar or Land Rover donor vehicle, doesn't have to be an F-Type, this might help in finding a used engine at a better price.
If you get a Land Rover unit you will have to swap the sump, oil pickup, and ancillaries over from your original engine, but the rest is the same.
A V6 to V8 conversion, while technically possible, is not economically viable in my opinion, if you're looking to just get the car back on the road then a used V6 is going to be the cheapest solution.
Dan's cat (06-23-2017)
Old 06-22-2017, 07:37 PM
RGPV6S's Avatar
+1 what happened?
Old 06-22-2017, 08:24 PM
Stohlen's Avatar
Motor mounts and bell housing would be the same actually. However the electronics would kill you unless you went full stand alone, and that likely would have negative affects on other areas of the car.
Old 06-22-2017, 09:03 PM
Mark G's Avatar
It would definitely decrease the value of the car. It would be very hard to find a buyer for a high end car with an aftermarket engine swap. The dealership won't do that work, so if it even worked at all, you'd be facing endless problems that wouldn't be covered under warranty. You'd hate it and want to get rid of it, but most if not all buyers wouldn't give it a second look. It sucks that you're in that situation, but I'm guessing there's a reason the engine blew and that Jaguar isn't replacing it. Don't make it worse on yourself. Either put the right engine in or sell it as is and get the V8 if you want that. How is it even possible to spec out a V6 to $99k anyway? I paid less than that for my '16 R.
Old 06-23-2017, 07:37 AM
Unhingd's Avatar
Received 4,637 Likes on 3,359 Posts
Were I in your situation, I would be having the same thought process. As I am in the car for the long haul, impact on market value would not be an issue for me. As the back of the engine block and the tranny (assuming AT) are identical between the two engines, the mechanical swap would be trivial. The only accommodation might be different engine mounts, and the entire exhaust system. The challenge as others have mentioned will be the electronics/programming. For certain the ECU would have to be replaced to match the V8. Perhaps much more would be need. I, personally, would chase this down a rat hole (while attempting to match an MT at the same time). Does $10-15k get you a new engine installed, or the existing one fixed. Retrofitting a new V8 probably can't come in under $30k.
Panthro (10-11-2023)
Old 06-23-2017, 08:10 AM
SinF's Avatar
I think unlocking full potential of V6 would be a better investment.
Just ask Unhingd for his engine mod wish list and follow that.
Old 06-23-2017, 08:22 AM
Unhingd's Avatar
+1. Even with a $15k repair bill, that would be your most certain and cost efficient way to achieve a serious power gain.
Old 06-23-2017, 09:58 AM
stmcknig's Avatar
But what happened ? Did the dyno pulls kill your engine ? If I read your past posts correctly you hadn't yet modded the car with either a tune or pulley ?
Old 06-23-2017, 10:20 AM
ek993's Avatar
https://www.jaguarforums.com/forum/f...2/#post1703210
Old 06-23-2017, 10:43 AM
stmcknig's Avatar
I need more coffee...read that a while back but didn't connect the user name....
I'll stand in the corner for a while.
Old 06-23-2017, 02:26 PM
Dan's cat's Avatar
Are you guessing, or do you know this for sure? I would imagine it would be getting a new ECU to program to the engine, but obviously I have no idea. That's why I am asking there is any real experience, or research on this.
Old 06-23-2017, 02:31 PM
SinF's Avatar
Mikey is known to guess a lot and he drives S type, not F type.
I anecdotally heard from my dealer that it is possible to change tunes via dealer tool (e.g. V8S to R). I don't know if it is possible to do the same with V6 to V8. I imagine controllers (ECU and so on) are the same, but wiring harness probably different.
Old 06-23-2017, 02:42 PM
Dan's cat's Avatar
I was assuming a new ECU for sure, but I guess I just don't understand why other electronics would be an issue. Isn't everything controlled by the ECU? Are there so many different electronic parts between the two platforms?
Not new, but low mileage v8, or V6 installed. The existing is being torn down right now to see extent or damage and possibility of repair.
