Winter tire sizes
Old 10-16-2018, 07:19 AM
mv007F's Avatar
Default Winter tire sizes
Looking to purchased some winter shoes for my F-Type AWD , my summer set up is 255/35/20 & 295/30/20.
Just wanna make sure I’m good to go with same sizes,
thanks
Old 10-16-2018, 07:47 AM
scm's Avatar
scm
scm is offline
Received 1,384 Likes on 1,051 Posts
The manual recommends Pirelli Sotto Zero in 255/35R20. load 97, and 285/30R20, load 99. Both at 36psi, 2.5 bar. Not for SVR, though.
Old 10-16-2018, 09:31 AM
mv007F's Avatar
@SCM
Thanks for the info & quick reply, very helpful!
Old 10-16-2018, 09:32 AM
herane's Avatar
This is exactly what I use with a separate set of winter wheels (same size as oem). Beware the sidewall is rather thin for winter, I had sidewall bubbles develop on both front tires.
Old 10-16-2018, 09:49 AM
mv007F's Avatar
@herane
thanks for heads up.
Where do you live?
Curious to know what type of winter you’re having in your area..
Old 10-16-2018, 09:51 AM
herane's Avatar
Originally Posted by mv007F
@herane
Where do you live?
Boston... So our winters and roads aren't the best...
Old 10-16-2018, 09:55 AM
scm's Avatar
scm
scm is offline
There are other threads on here about recommendations for winter tyres, Pirelli isn't a hot (or cold!) favourite .....
Old 10-16-2018, 11:01 AM
fujicoupe's Avatar
Banned
@herane
Where do you live?
Definitely in the early stages of winter here: Got down to 69 degrees the other night; had to break out the sweater to take out the trash.
Old 10-16-2018, 01:38 PM
Paul champagne's Avatar
Can't be worse than Montréal, I can tell you that.
Not sure what it will be like this winter, but currently, most every street is in construction.
Old 10-16-2018, 01:47 PM
mv007F's Avatar
Paul is 200% right , roads in Montreal are the worst...maybe the worst in the world lol
Thank god I don’t have to commute downtown often
Old 10-16-2018, 01:52 PM
It will be very, very nice once it's all done. The problem is that we will all be flying Jags by then
Old 10-16-2018, 03:43 PM
scm's Avatar
scm
scm is offline
Originally Posted by fujicoupe
Got down to 69 degrees the other night ...
Blimey, in the UK we'd be firing up the BBQ at that temperature!
samy
02-02-2017 11:47 AM
gmaharaj
Canada
11-19-2016 10:14 AM
Manco
02-05-2011 12:50 AM
supercharged
01-02-2011 12:35 PM
johnlittle01
05-12-2010 11:35 AM
Quick Reply: Winter tire sizes
