wing spoiler
Received 3,128 Likes
Yep, see this post: https://www.jaguarforums.com/forum/f...4/#post1614196
Not quite as simple as removing a fuse but easy enough.
The fuse that applies to the spoiler also applies to a couple of other things that you don't want to disable.
powerhouse (11-17-2018)
Came across this wing spoiler, any views , picture is of a car that is fitted with the same wing
https://www.aliexpress.com/item/Carb...747b13493iw81e
Yep, it looks good.
The main downside I can see is you have to drill or "self-tapper" some holes in the spoiler lid to mount it (probably four, maybe two) and then what if you didn't like it and/or it fitted poorly? You would be stuck with those holes and you would probably need to replace the spoiler lid.
I for one don't like the idea of it being held on with self-tappers (and maybe some tape), proper bolts would be much better.
Also the pics and text in the linked ad conflict on the appearance of the two mounting posts, are they CF or are they black or grey primer which then needs to be painted?
We need a guinea pig to test it!
I have the SVR style CF wing spoiler from Paramount Performance mounted on my F Type R coupe. I got the shorter feet so it’s about the same height as the SVR wing and what you have pictured above. The spoiler mounts through the original lid and is attached with bolts, not self tapping screws like the Chinese versions (scary).
I did have it professionally installed by a specialty shop. The factory spoiler has to be disabled. On the R, if you disable the spoiler by unplugging it, the car will be limited to 130 mph and throw a warning on the dash. The only way around this is to cut the rod that makes the spoiler go up and down, or install the Jaguar electronic unit that replaces the motor... this is what I did and it worked seamlessly.
powerhouse (11-18-2018)
He reckons it's not something that can be done via SDD or the CCF and it's buried deep inside the code in one or more modules.
BruceTheQuail (11-25-2018)
JC_In_83814 (02-08-2020)
WTB[Central US]: WTB: Rear Spoiler/Wing for pre-facelift XJS
Safari
06-22-2016 06:32 AM
Ubad2
02-25-2016 09:13 AM
Ubad2
12-25-2015 12:45 PM
rscultho
04-12-2012 03:24 AM
