Compass Calibration failed
Old Nov 6, 2024 | 03:11 PM
Brian G's Avatar
Default Compass Calibration failed
After removing the Dome light unit and unplugging the 2 associated harness plugs and subsequently reinstalling it all, I noticed that the mirror compass had reset itself to the "C" calibrate mode.
i checked that the deviation zone selected was correct and then drove in slow circles for a few minutes. No joy on the calibration process.
Regardless of tactic to restart the compass it always returns to "C".
I have tried, ignition sw cycle, deviation zone change, mirror compass sw cycle, drive in opposite direction circles. Still no joy.
The compass feature functioned properly before the Dome light unit R/R.
Any insight?
Old Dec 9, 2024 | 12:58 PM
Brian G's Avatar
Has nobody else had this issue?
Old Dec 9, 2024 | 09:58 PM
Rex's Avatar
Rex
Had a similar issue with my S Type. Took about 1/2 hr of circling to calibrate.
Old Dec 9, 2024 | 10:05 PM
Brian G's Avatar
Yikes!!
Old Mar 17, 2026 | 02:11 PM
Ianbat1507's Avatar
Default Compass calibration failed, XK8 4.2, 2002
I've tried to reset the calibration of my rear view mirror compass. All I get now is "C" followed by numbers 1-15, presumably calibration zones (for the USA?) How do I recalibrate the compass for the UK (North east?)please
Old Mar 17, 2026 | 06:37 PM
Stumpy's Avatar
Here are the relevant pages from the Jaguar manual. Hope it helps ?
Old Mar 17, 2026 | 06:53 PM
Brian G's Avatar
My 2004 XK8 mirror compass appears to have a mind of its own. The recalibration process sometimes takes 4 circles to complete and sometimes 30 circles won't do it. Then, once it is set it can hiccup and show a direction 30* or 90* or 180* off, without any apparent reason.
Luckily, I live on an island where it takes some real effort to get lost.
Old Today | 03:55 AM
Ianbat1507's Avatar
Thank you for your help. I've managed to get a direction showing on the compass, but it is approx 180deg out. Despite many journeys, it hasn't reset itself. I suspect the problem is that the compass/mirror was not correctly reinstalled after the windscreen was removed for re-upholstering. I can feel something very loose at the front of the mirror against the windscreen. Can the mirror be removed without removing the windscreen, and if so, where do I go from there?
tompullizzi
Jan 25, 2023 06:39 AM
Dan R
Dec 21, 2017 05:53 PM
ChuckB
May 22, 2014 07:25 AM
Craig Schmidt
Mar 23, 2011 05:05 PM
