2002 S type v6 battery keeps dying
Hello everyone,
I am trying to diagnose what may be the issue on my 2002 Jaguar S-Type as the battery keeps dying every now and then, I changed the battery recently as I thought it was the problem unfortunately it didn't solve it, I did a battery leakage test but it turned out to be fine.
Note that sometime the car works for several days with no issues.
Disconnected the negative terminal while keeping the positive connected, took a voltmeter put one end on the negative terminal and checked each fuse that I could reach to see if it would drain while the car is off.
I don't know what the exact name is but here is what I did:
As advised, you will do well to follow a systematic approach, as set out in our write-up which JagV8 pointed to and Karl has linked. Read all the posts because there are several handy hints beyond my initial posts.
Cheers and best wishes,
Mark Scotton
Aug 10, 2012 01:46 PM
sibby1979
Oct 7, 2010 06:08 AM
snowcain
May 28, 2010 03:00 PM
