NORMA hose connector removal
Old Yesterday | 07:57 AM
Pantera928's Avatar
Default NORMA hose connector removal
I have been looking at the large"norma" connector on the octopus hose and trying to figure out how to remove it. I have looked at several old posts but I am still not clear.
Is it some sort of push/pull method?
THanks
Old Yesterday | 08:38 AM
motorcarman's Avatar
I just blow it with some compressed air to remove any grit or debris from the connection.
Then I spray with silicon aerosol to lube it.
Push the outer most ring back against the plastic towards the rubber hose.
Grab the assy and twist to break it free if it is stuck on the metal pipe.
I use a heat gun and gloves if it is still stuck and with pulling and twisting it will release!
Old Yesterday | 12:23 PM
Y2KJag's Avatar
I just used a screwdriver to pry it up and break it in several places until I got it off. I was replacing the octopus hose, so no reason to be delicate.
Old Yesterday | 12:49 PM
Breaking the plastic 'fingers' works when you have no intention of reusing the connector.
Try not to scrape the metal pipe too much or the 'O'ring seal will leak.
Old Yesterday | 02:27 PM
Pantera928's Avatar
Ophitoxaemia
Oct 11, 2024 06:38 AM
David Dougherty
Nov 4, 2022 08:35 AM
brgjag
Nov 13, 2014 06:35 PM
srpope80
Jan 26, 2012 04:02 PM
SilverXJ
Jun 1, 2010 12:06 PM
