That photo is showing the jet set extremely rich, it is not level with the jet bridge, I doubt if the car would even run with it like that, it would be flooding.
it doesn’t… hence my begging :-)
but I adjusted to be as flush as I can tell and still not running
It's supposed to be flush with the jet bridge initially, but then you turn in the "richness" screw 1.5 turns for the first start up. (doing this from memory, but I think it's 1.5 turns, check the manual and confirm that)
If the jet is level with the bridge, it's now too lean and the car will not start.
Red arrow is the jet bridge and the green arrow is the jet.
