valve cover gasgets leaking om 5.0L XK
THAT is a HUGE and EXPENSIVE job to undertake on a 5.0 engine. Certainly not an easy DIY.
One word of caution: make sure you use a penetrating oil to let the fuel injectors soak for several days prior to attempting to remove them. Some require over a hundred strokes with the slide hammer to get them to come out of their bores, but others may come out with the fuel rail.
It annoyed me because a previous owner had to replace the gaskets TWICE in 5 years or so. Both times just replaced the injector seals. A set of injectors from ROCKAUTO is like 1600 NZD so about 950 USD. Seems worth it for me.
Gottabekidding
Feb 6, 2024 07:32 AM
locrao_pt
Apr 10, 2015 11:47 AM
