valve cover gasgets leaking om 5.0L XK
Old Apr 30, 2026 | 10:21 PM
Bob OB's Avatar
Default valve cover gasgets leaking om 5.0L XK
What have others done? looks like a lot of stuff is gonna need to be moved...
Old Apr 30, 2026 | 11:28 PM
Cee Jay's Avatar
Try tightening any bolts you can access first. It may be something easy.
Old Apr 30, 2026 | 11:44 PM
kj07xk's Avatar
I had all the bolts removed, except the last one, and when I got to it I found that it was totally loose (without its rubber grommet, it would have fallen out). Since I’d gone to all the effort, and had the parts, I replaced the gasket.
Old May 1, 2026 | 07:17 AM
LJRXKR's Avatar
You also will need to remove the injectors. Depending on how many miles and history, It might be worth replacing the injectors too to save you pain down the road.
Old May 1, 2026 | 09:03 AM
Bob OB's Avatar
Thanks guys, will try all suggestions.
Old May 1, 2026 | 09:10 AM
Cee Jay's Avatar
THAT is a HUGE and EXPENSIVE job to undertake on a 5.0 engine. Certainly not an easy DIY.
Old May 1, 2026 | 10:26 AM
NBCat's Avatar
One word of caution: make sure you use a penetrating oil to let the fuel injectors soak for several days prior to attempting to remove them. Some require over a hundred strokes with the slide hammer to get them to come out of their bores, but others may come out with the fuel rail.
Old May 3, 2026 | 10:46 PM
LJRXKR's Avatar
It annoyed me because a previous owner had to replace the gaskets TWICE in 5 years or so. Both times just replaced the injector seals. A set of injectors from ROCKAUTO is like 1600 NZD so about 950 USD. Seems worth it for me.
Old May 4, 2026 | 10:33 AM
Bob OB's Avatar
Thanks, I won't attempt it! Bob
Ace VDP
Jan 3, 2026 01:04 PM
Gottabekidding
Feb 6, 2024 07:32 AM
Luis LCG
Jun 2, 2020 08:39 PM
jlpatton
Jul 9, 2019 02:46 PM
locrao_pt
Apr 10, 2015 11:47 AM
