Velocity AP valvetronic exhaust impressions/thoughts
As some of you may have noticed, I recently installed this axel back on my 2024 R…I just wanted to give my thoughts on the difference it has made with my car for anyone that might have an interest, might be considering purchasing it, etc…
Here is a link to my install thread for anyone interested —>
https://www.jaguarforums.com/forum/f...k-only-296101/
I’ll start by mentioning my goals when I set out to purchase this exhaust. As most of us know, these newer F-types have a GPF filter integrated into the stock CATs. As a result, these cars are notably down on exhaust noise compared to the older cars that are not fitted with a GPF.
Even with the GPF fitted it still sounds surprisingly good when one uses a valve controller to keep the valves fully open. Even before the exhaust I was quite satisfied to be honest, but I always found myself itching to have just a bit more in terms of exhaust noise. I didn’t want over the top gunshots insane or anything, just a bit more.
After driving this car for 2 days now with the new exhaust fitted I can say for sure that this move delivered exactly what I was looking for. Notable differences that I perceive —>
1) Right off the bat, the same beautiful tone is maintained…Generally…I was a bit concerned that it might change the stock tone too much, as I really like that. It did not, so I’m a bit relieved. It’s so hard to know for sure from videos on the Internet. Impossible I find. Buying exhausts involves a bit of a leap of faith in my view, unless you know someone with the exact setup to hear in person. This worked out for sure, so I’m quite pleased.
2) It is most definitely louder than stock with the valves open. Undeniably. Not crazy louder, but it noticeably has more volume. To the point where I am glad I have an ASR valve controller that allows me to have the valves completely closed throughout the entire cold start. The difference is enough where I would now feel a bit concerned that I’d be upsetting the neighbours in comparison. I’ve come to the conclusion that, if it’s in the afternoon I will not be that concerned to do full open cold starts, but if it’s before noon I’m just gonna do cold starts with the valves completely closed the entire cold start (until it idles down).
3) It’s not just louder, it’s deeper. Much deeper. Like, I’m in love deeper. Intoxicatingly so. Amazing. The sound is just so full and filled in compared to stock. Beefy. Not sure how to describe it other than to use those word. Like, amazing.
4) Overruns. Much more pronounced. In a good way. Very nice.
5) Idling. With the stock setup I found I struggled to hear the car. Yeah, not now. I can hear the exhaust so nicely now from inside the car. SO much better in this regard. It is one of my favourite changes.
6) Rasp. Jury is still out on this, as I need more seat time, but I have the sense that it is lowered. When you’re into it I find it is still there, but when down shifting aggressive in sport manual mode I think it’s a bit more reduced. I think, but again, I think I need a little more time to say for sure. This is my initial impression.
7) Drone. NONE. Perfect.
8) Better look. This is subjective, but in my view the tips look WAY better than stock. Like, in person, it’s not even close. Most of my buds agree. Very aggressive looking.
Anyway, all this to say I’m incredibly pleased. If you are like me and want to raise the roof a bit with your newer GPF-fitted F-type, without tuning and changing environmental equipment (GPF, CATs), this may be for you. I was also concerned with warranty issues. This is not invasive at all, and could be easily removed if needed, so warranty problems are not a problem.
Thanks for the review. I have a MY19 6cyl, which despite being pre-GPF, is nonetheless too quiet most of the time, notably at idle. Although I have the active exhaust with the cabin switch, I’ve been dissatisfied and thinking of an aftermarket exhaust.
Yes, my car barks on cold starts, but quiets down pretty quickly. I drive almost exlusively in Dynamic plus shifter Sport (hereafter, DS), but still would like more ruckus. I get good pops n’ bangs on overrun in DS (and the attendant poor fuel economy), but really find the idle and low speed sound to be feeble.
If there were a way to showcase thhigh-tension sound of the V6 at speed at lower RPM, that’d be great, because as it now, even in DS, the car is essentially silent between 900rpm and 3k rpm, which is exactly where I do a lot of driving in town.
Again, I personally don't think videos of exhausts are all that accurate or representative, but I guess it could give an idea.
My suggestion would be to first get clear on what the deal is there. If it was the case that your car is not truly able to keep the flaps open in the lower revs all the time, well, that would be a cheap fix for you. Given that you don't have a GPF to contend with, getting the flaps to stay open full time when you want them to would likely be the only battle you need to win. It would make all the difference. Solving that issue made a massive difference even on my GPF equipped F-Type.
For instance, I googled whether your car would truly have the exhaust open all the time and it spat out something similar to what I've read...i.e.: That it does not truly keep them open, and the ECU is overriding and actually keeping them closed in the lower RPMs... -->
"On some newer models (roughly MY18+), the button may not keep the valves open 100% of the time at idle to comply with noise regulations, often opening fully only above certain RPMs."
This sounds like what you don't like, and that would be easy to solve with a controller like I have from ASR. Because you don't have a GPF issue I think your issues are solved through some combination of a valve controller like the ASR unit I have, or in a worse case a tune, but the valve controller could possibly be all that's needed? Would be a lot cheaper than a quality aftermarket exhaust.
Put it this way, if I didn't have a GPF I doubt I would have needed an axel back to satisfy what I was looking for. Just my ASR probably would have done it for me. My best guess anyway...
Something to think about. Do you know definitively that your car is for sure keeping the valves open throughout the entire rev range when you want it to?
Have you tried pulling the active exhaust fuse? (I think F15 for you, F43 for me.) I have active exhaust, but not switchable active exhaust. I added a relay and remote to defeat F43, and when I activate it, it’s MUCH louder at low RPMs, like night and day. You should try that first. I should find someone to help me record a few videos, meant to do that a few years ago.
Yeah I don't disagree, but having more examples of different setups can still be helpful for some.
You will notice a change (for the better) after about 500 miles once the exhaust has had a few heat/cool cycles on all the metal. It definitely takes that to 'wear in', if that's the right terminology. I had similar impressions to you out of the box, but it gets even better after a few hundred miles.
StormtrooperFtype
Dec 22, 2019 05:20 PM
