95 xj6, cranks but doesn't start
Old Dec 18, 2007 | 11:46 PM
dougs02's Avatar
Default RE: 95 xj6, cranks but doesn't start
Check the fuse for the fuel pump. Also turn the key on and have someone listen at the back of the car for the fuel pump working briefly. I think it shuts off after pressure is built up. I don't have a XJ6 anymore but maybe someone can tell you if there is a valve on the fuel rail to check fuel flow.
Doug
Old Dec 19, 2007 | 09:26 AM
ken@britishparts.com's Avatar
Check the crank position sensor as well.
Old Dec 19, 2007 | 12:35 PM
I suppose the next step would be to through a manual gauge on to see what kind of fuel pressure you're running.
Old Dec 22, 2007 | 09:28 AM
jag_genius's Avatar
you might be loosing fuel flow.. the hose off the pump tends to fall off.. or just be slightly coming off .. and create long cranking
Old Dec 23, 2007 | 04:58 PM
jag_genius's Avatar
yep or it can be just a dead fuel pump
Old Feb 28, 2010 | 03:52 PM
italcarnut's Avatar
Is there a relay for the fuel pump that may fail. I am finding myself with the same problem. Went to start the car today and no joy. Seems I have spark, but need to check for fuel. I will also look for the crank sensor. What should I look for besides a connector/ Anything?
Old Yesterday | 11:49 AM
wardhill68's Avatar
Being that i live alone can i pull the fuel pump fuse tuen the ignition to position two then return to the trunk and reinsert the fuse to hear the fuel pump pressurize? Thanks
Old Yesterday | 07:09 PM
Parker 7's Avatar
the fuel pump will come on for 3 seconds only , this " charges " the fuel lines and not a priming of the cylinders . Hold foot off pedal as pumping the pedal does nothing . Holding the pedal to floor will cut off the injectors by design
The fuel pump will come back on when the CKPS sees engine rotation , safety design
This holding to floor is one way to re establish the oil film on the cylinder walls , this is the walls get into a bore wash condition which does happen
The fuel pump can be powered on by jumping the socket 3 ( Hot at all times battery ) to 5 ( pump motor )
This will drain battery with keys in pocket , this is also a stranded on side of road tool to keep in trunk
BEST MEDIUM GAUGE WIRE WITH BLADE TYPE WIRE END FOR BEST CONCUCTITY
Old Today | 03:12 PM
wardhill68's Avatar
Thank you
Sids-Jag
XJ40 ( XJ81 )
19
Nov 29, 2014 06:40 AM
Ronan W
XJ40 ( XJ81 )
May 15, 2013 10:29 PM
davep84
Jan 22, 2013 03:20 PM
RMally
Jul 7, 2011 09:07 AM
rpeppers
Oct 6, 2009 03:09 PM
