95 xj6, cranks but doesn't start
Old Dec 18, 2007 | 11:46 PM
dougs02's Avatar
Default RE: 95 xj6, cranks but doesn't start
Check the fuse for the fuel pump. Also turn the key on and have someone listen at the back of the car for the fuel pump working briefly. I think it shuts off after pressure is built up. I don't have a XJ6 anymore but maybe someone can tell you if there is a valve on the fuel rail to check fuel flow.
Doug
Old Dec 19, 2007 | 09:26 AM
ken@britishparts.com's Avatar
Check the crank position sensor as well.
Old Dec 19, 2007 | 12:35 PM
I suppose the next step would be to through a manual gauge on to see what kind of fuel pressure you're running.
Old Dec 22, 2007 | 09:28 AM
jag_genius's Avatar
you might be loosing fuel flow.. the hose off the pump tends to fall off.. or just be slightly coming off .. and create long cranking
Old Dec 23, 2007 | 04:58 PM
jag_genius's Avatar
yep or it can be just a dead fuel pump
Old Feb 28, 2010 | 03:52 PM
italcarnut's Avatar
Is there a relay for the fuel pump that may fail. I am finding myself with the same problem. Went to start the car today and no joy. Seems I have spark, but need to check for fuel. I will also look for the crank sensor. What should I look for besides a connector/ Anything?
99xk8guy
Sep 29, 2025 10:51 PM
JarodL
Mar 7, 2024 01:39 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
