CD changer: E-01 error code
Old Sep 11, 2012 | 11:29 AM
Redeye's Avatar
Default CD changer: E-01 error code
Suddenly from no where, after finishing playing the 5th CD (which happened to be the brilliant Doors compilation album - didn't have a 6th loaded), this E-01 error came up on the display panel. Tried to remove the changer from its holder but it makes a noise for a couple of seconds as per normal but then the CD holder doesn't pop out!
Looking up the error code in the manual its simly states 'See your Jaguar dealer'. Surely there's an alternative to paying £145 for an hour of their time?
All suggestions welcome...
Jules
Old Sep 11, 2012 | 11:32 AM
Jeff in Tucson's Avatar
Default Me, too.
The exact same thing is going on for me. It happened a couple of days ago. I will be replacing the audio system soon, so I guess that I'll live with it until then. I already have new speakers in, ready for the new head unit.
Good luck!
Old Sep 11, 2012 | 12:27 PM
Jag#4's Avatar
One of the common errors on the Jag CD changers. Search forum for "CD changer E-01 error code" (use Google, it's faster and more accurate).
Plenty of threads on the board for DIY fixes. Most are simple & quick, but be aware that they will come back. These units are not that reliable and depending on your MY, getting old.
Old Sep 11, 2012 | 02:02 PM
dennisw's Avatar
happend to me few times..jiggle the caddy as you push push the eject button..it will come out.dosnt like that disc..not the fab DOORS album..the disc..dont do any thing rash..it will come out
Old Sep 11, 2012 | 02:58 PM
Redeye's Avatar
Thanks dennisw. I saw your post from earlier this year and have just come in 15 mins of trying, but it ain't coming out. I can see the 5th CD is still 'out' within the changer. I've jiggling everything all ways but the eject motor just whizzes for a couple of seconds then nothing. I'll give it another go tomorrow in the day light - and may be when the old blood pressure has lowered a bit!
Tried the flat screwdriver under the changer method I've read on here too, but nawt. I really don't want to try and get the whole CD unit out if I can help it, nor spend any more money - just paid £135 for a new battery last week!
Old Sep 12, 2012 | 04:58 AM
Originally Posted by Redeye
.............. Looking up the error code in the manual its simly states 'See your Jaguar dealer'. Surely there's an alternative to paying £145 for an hour of their time? All suggestions welcome...
Jules,
Jaguar CD players appear to have a very low second hand value in the UK.
There's several listed on eBay starting at £50 which could be a more cost effective solution than a repair.
Old Sep 12, 2012 | 11:24 AM
scube's Avatar
It’s a similar set up to the one I had with my Range Rover P38
Dreadful thing finally gave up on it but I managed to get an MP3 adaptor to fit into the head unit.. Sadly don’t seem to be able to do the same with my XK8
Any how, to the answer.
I use to take the cover off the CD changer and very gently push the curved arm which moved the disk in and out of the changer.
Sadly once it starts doing this it really won’t stop. I tried putting some very fine oil on the mechanism but that only worked for a few weeks and it would stick again.
So you will be able to get your CD of the doors back out
Good luck
Old Sep 14, 2012 | 07:32 AM
Redeye's Avatar
Default CD Error code E-01 RESOLVED (for now!)
I was within 30 seconds of probably doing something to the CD player that I'd have regretted, but then.... from absolutely nowhere.... out she popped!!
The remedy was a knife (as in knife & fork), inserted between the cartridge and the white base, increasingly violent wiggles of said knife up & down, repeated pushing of the eject button and about 15 mins of patience!
I have no idea though whether the issue was the Doors album, CD5, or the machine generally. I guess there's only one way to find out...
Old Sep 14, 2012 | 09:13 AM
Jag#4's Avatar
For what it's worth, mine never liked older generation ripped CDs or blank slots. Not having all slots filled often upset it.
Old Nov 14, 2012 | 07:10 PM
kzj42g's Avatar
Default CD E-01 message
Taking a straight slot screw driver, or letter opener, and applying slight upward pressure on the bottom of the cd magazine while pushing the eject button should eject the magazine. That should clear the code, and you will see a message that says "magazine empty" or words to that effect. Exercise each of the 6 magazine slots by checking that each disk is in its place, re-insert the magazine, and you should be back in business.
Old Nov 15, 2012 | 05:14 AM
dennisw's Avatar
strange!!! mine always jams on cd5..
these units are junk
Old Dec 17, 2012 | 07:57 PM
jamjagboy98's Avatar
do i put the dial on CD before trying this knife and forks thung ?
All reponses will be appreciated
TREV
Old Dec 18, 2012 | 07:25 PM
kzj42g's Avatar
Smile
No, in fact you can perform this exercise with the car unpowered.
Old Mar 7, 2013 | 11:12 AM
riem's Avatar
Banned
same+1, but when i want to fix it by a screw driver, it gets good automatically......
Old Aug 14, 2017 | 12:23 PM
spyder9014's Avatar
Thanks for the info. My battery had died and a CD was in the player. I tried the wiggle and eject but nothing happened other than some clicking in the changer. I noticed that the bottom CD was in the player. I disconnected the battery waited a few minutes, reconnected and turned the head unit to radio and back to CD. I heard the CD retract into the cartridge and was able to eject it. All is now good, no lost CD no damage to the player, everything works, yea!!!!!
Old Dec 11, 2017 | 04:43 PM
mauipeterb's Avatar
I got the dreaded CD E-01 error code a couple of days ago. (I seem to remember having gotten it several years ago and paid my local jaguar repair shop.) The blue eject button was inoperative, so I decided to try the fix recommended on this forum. I used my Swiss army knife, inserted about 2 inches, and swept from right to left underneath the magazine. I heard a click behind the blue button, as though a CD was retracting. I pressed the blue button and the magazine ejected. I then put the key in the ignition and got the NO MAGAZINE message. I removed all the CDs from the magazine (there were only three and they were all ripped CDs), wiped them clean and inserted them, adding three more so the magazine was full. I reinserted the magazine, fired up the CD player and it came up with CD 1 TRACK 1. I didn't try any of the other CDs but I'm assuming all is well. BTW, I have a blog if anyone is interested: https://ourjaguarxk8.blogspot.com/
Old Yesterday | 09:24 PM
JXR's Avatar
JXR
Default Dead battery fixed it!
I don’t want to jinx myself but I had let my XJR battery go dead. I put it on the trickle charger overnight and miraculously when I started it the error code on the cd changer was gone!
Old Today | 04:20 AM
Hunty60408's Avatar
Had it happen from time to time in 2 X100s over the years. They are not ‘Jaguar’ units and as it says online are used by multiple car brands. Even the newest in an X100 will be over 20 years old and that’s a lot of ‘eject’ cycles. I give mine a sharp tap when it shows E-01 and that generally cures it for a while.
I have found that Spotify/Apple Music via a £10 FM Bluetooth transmitter is far more convenient than the CD stacker in the boot, charges my phone and works with phone satnav too.
Bcrary3
Feb 21, 2023 04:29 AM
Terry H
Jul 4, 2017 05:48 PM
KarimPA
Sep 27, 2015 08:46 AM
Jpav27
Sep 26, 2015 03:33 PM
tonyforman
Sep 10, 2015 07:23 PM
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
