help !!
Old Jan 2, 2016 | 11:15 AM
chriswfisher's Avatar
Default help !!
Hello. I'm new on here and have a problem.
My wife bought me an XJ8 3.2 1997 for my 50th birthday. And it is in showroom condition And drove beautifully. I put it in to storage for 3 months. When I went to get it the battery was flat. So we jump started it. It started immediately and was running sweetly.
The problem is its stuck in limp mode and saying gearbox fault, and stability failure. Also the interior lights aer permanently on and all lights are flashing when switched on.
Please advise me what to do.
Chris.
Old Jan 2, 2016 | 11:19 AM
jimbov8's Avatar
These cars very sensitive to a lack of battery voltage. You need to have the battery fully charged first and then see what happens.
Then we can progress further.
Old Jan 2, 2016 | 02:32 PM
Welcome to the forum Chris,
I hope you jump started it correctly using the method detailed in the handbook? These cars have a lot of sensitive electronics which don't respond well to spikes.
Old Jan 2, 2016 | 04:05 PM
andrew lowe's Avatar
+1 on the battery, these cars are VERY fussy about voltage and battery condition.
A battery that would be OK on 90% of other cars will just give a Jag a brain fart, and cause all sorts of weird/random faults, or lights to occur.
The symptoms you describe are typical flat/ knackered battery traits.
Old Jan 3, 2016 | 03:17 PM
charlie57's Avatar
Banned
I agree with Andrew having been a member of jaguar clubs for a few years now, a bad battery can cause lots of problems. if I were you I would get a new one, for the sake of a £100 or less
Old Jan 4, 2016 | 02:56 AM
SteveSheldon's Avatar
+1 on everything above - take that battery off, make sure the boot is kept open (unless you are sure the boot lock works with the key) short the plus to earth on the leads, and fit a new battery.. you may well find all your problems go away..
Old Jan 16, 2016 | 09:04 AM
Default thanks
Thanks for the replies and advice given. I disconnected the battery and fully charged it. Now the alternater is charging. The interior lights don't flash. But when I rev the engine, the dashboard illumination goes out and charging light comes back on. Also it says after the dash lights go out gearbox fault and asc fault. Any ideas.
Sorry about the delay in replying. But I work away from home a lot recently.
Old Jan 16, 2016 | 09:25 AM
jimbov8's Avatar
Check the ground points in the engine bay are free from corrosion, clean and tight also the ground from the battery.
Old Jan 16, 2016 | 09:42 AM
Jagfixer's Avatar
Have a load test done on battery. Might show good voltage but was stored for 3 months and we do not know how old battery is. There is a date code on battery. recharging the battery only lasted a little while, new battery is recommended. if it is a newer battery by you, will be in warranty, if previous owner bought battery, no warranty.
Acebars
53
Sep 19, 2016 04:11 PM
BobRoy
Jan 21, 2016 04:14 PM
Boomy
Dec 31, 2015 03:36 AM
ubetido
Australia - Queensland
Dec 29, 2015 02:38 PM
scooby73
Dec 28, 2015 12:41 PM
