s-type 3.0 auto 2001 gearbox will not go into reverse
Old Aug 9, 2012 | 05:46 AM
vibman10's Avatar
Default s-type 3.0 auto 2001 gearbox will not go into reverse
Hi all
new to this have a 2001 3.0 auto s-type jag that will no go into reverse gear but gosse into drive can anyone help with this thanks vibman
Old Aug 9, 2012 | 06:21 AM
abonano's Avatar
Possible causes - reverse solenoid issue, (could be stuck or shot) shifter issue, haeve you checked the shifter cable that goes from the shifter to the trans? Finally, when was the trans fluid serviced last?
Old Aug 9, 2012 | 03:07 PM
Fraser Mitchell's Avatar
Hmmm, interesting, because you pass 'R' on the way to '' (Drive). suggest you check the shift cable at the transmission end as suggested. If no joy, (i.e it all looks tickety-boo), then you need to see an auto box specialist. There are plenty around, you don't need to go to a Jaguar main dealer, this box is used by many car makers.
Sprayall
May 30, 2021 08:13 AM
cissdm
May 3, 2016 06:02 AM
the whittys
Sep 15, 2015 01:47 AM
Sprayall
Sep 3, 2015 07:49 PM
pnwrs2000
Sep 3, 2015 11:55 AM
