US Western AK, CA, NV, OR, UT, HI, WA, ID
Transmission shop for 2000 XK8, East Bay, CA area?
Old Feb 14, 2019 | 09:14 AM
Ophitoxaemia's Avatar
Default Transmission shop for 2000 XK8, East Bay, CA area?
ZF5HP24 in a 2000 NA XK8 Coupe.
Having trouble finding a shop that will service possibly a cracked valve body. Thank you!
Old Sep 10, 2023 | 10:41 AM
BobRoy's Avatar
I would just change the oil and filter. I would not flush the transmission. If you want to make sure you get a high percentage of the old oil out change it again in a few hundred miles. After I would do a A drum repair I would change the oil twice in the next 1000 miles to get out as much of the fine metal particles left after the A drum failure.
Speaking of the A drum I believe more importantly you change out the pressure regulator in the transmission to the updated Transgo regulator. It is possible that spikes in pressure due to faulty regulator might contribute to the A drum failure. Linked is a post I did on the repair.
https://www.jaguarforums.com/forum/x...pgrade-179012/
Also make sure you have the updated timing tensioners.
Good luck with your car.
bcucharternet
Sep 12, 2024 04:59 AM
chrisant
Nov 19, 2015 10:16 PM
bcucharternet
Oct 31, 2015 09:27 PM
X-man
Jan 25, 2015 05:40 PM
Nce Kty
Dec 3, 2011 01:04 PM
