info needed on greasing prop/drive shaft
Old Feb 19, 2012 | 08:50 AM
iownme's Avatar
Default info needed on greasing prop/drive shaft
morning all...i'd like to do the propshaft bearing greasing procedure, but i don't know where to get a needle attatched to a grease gun from...is there some kind of tool for the job...or is it a "make it yourself" kinda deal?
Old Feb 19, 2012 | 10:40 AM
clyons's Avatar
I got mine at Autozone.
Autotec/1 1/2 in. stainless steel grease injector needle (57413) | Grease Gun Accessories | AutoZone.com
Old Feb 20, 2012 | 04:56 AM
iownme's Avatar
i just read the faq for doing the procedure...and a poster with an 04 3.0 (what i have) said his center bearing did not have the 3 notches to insert the needle into. No-one answered that post, so i'm wondering what to do if i get under the car and find i also don't have those notches....anyone else come across this on their car? and what is the answer?
Old Feb 20, 2012 | 06:44 AM
iownme's Avatar
i just looked under the car and i do not see the notches to insert the needle. i attached a pic..perhaps someone can suggest where to insert it (i hope) :+)
Attached Thumbnails info needed on greasing prop/drive shaft-ph-001.jpg
Old Feb 20, 2012 | 10:57 AM
Luka's Avatar
Under the cap there is a standard bearing number 6013 2RS. I do not know what kind of notches you expect to find on it. The whole bearing is easy to change.
Old Feb 20, 2012 | 12:06 PM
iownme's Avatar
in the FAQ about greasing the driveshaft bearing it shows in the pic and text that there are 3 notches around the bearing where a needle can be inserted to grease the bearings.
Another forum member with an 04 X noted that his bearing did not have these notches (at 10o/c 6o/c and 2o/c) mine doesn't either...guess now its a moot point as i now have found that the bearing assembly is totally shot. Thanks for the info about being able to replace just the bearing.
Sorry if i've been too quick to re-post a new thread about the bearing being loose
Old Feb 23, 2012 | 05:02 AM
mr.xtype's Avatar
Luka, my drive shaft is shot at the hanger bearing area. I have been told I need to buy a new entire shaft as ths cant be fixed. Are you saying I can open this up, install a new bearing and everything will be okay? If so where so i buy the bearing and how do I install the new one?
Old Feb 23, 2012 | 03:02 PM
Luka's Avatar
Originally Posted by mr.xtype
Are you saying I can open this up, install a new bearing and everything will be okay??
Yes, that's what I say. But I do not know whether you can do, it's a little bit tricky
Old Feb 23, 2012 | 09:36 PM
iownme's Avatar
does the driveshaft just slide through the bearing? or does it need to be taken to a machine shop to remove the old bearing and have the new one fitted?.
i just ordered a new bearing online for about $20...good quality from a bearing manafacturer. i called them and spoke at length about bearings in general...very knowledgeable. I dont have their info in front of me...let me know if you want me to post the contact info. It seems the mark up on bearings at the auto store is quite high
Old Feb 24, 2012 | 04:17 AM
mr.xtype's Avatar
Yes please post the contact information, part number etc.
I am wondering if anyone has done a "how to" with pictures.
I havent been on he forums in quite some time but joined back in 2008 and in 2009 when I had to replace my prop shaft due to whining no one mentioned it can be repaired.
Just wondering if this was common knowledge or if someone discovered this recently.
When do you think you are going to get yours fixed? I would love to hear how it turns out
Old Feb 24, 2012 | 06:14 AM
iownme's Avatar
here is a link to the bearing you need. phone # is 863-248-8499
6013-2RS, 6013-ZZ Premium Ball Bearings, 65x100x18 | 1000620
as soon as it arrives i'll be doing the work. I'll try and compile a "how to" with pics.
you can also google the bearing part # which is 6013-2rs.
I'm not convinced my bearing is the problem as there is a huge amount of play between my driveshaft and bearing carrier. If this was a shot bearing i'm sure my ride would be much worse than it is. I'm thinking there is something inside the d/s support like a rubber donut that has failed. Will post back once i have mine opened up.
It seems were on our own with this problem...no advice from any jagtechs or forum experts...just you..I and google
Old Feb 27, 2012 | 09:21 AM
mr.xtype's Avatar
which one should we get? The one wih the metal shield or rubber seal?
Old Feb 27, 2012 | 11:50 AM
Luka's Avatar
Definitely 2RS, rubber seal.
But finally, I do not recommend this whole procedure, аfter I went through it.
Тhe bearing and protective caps were originally sealed in rubber. After removal, they are destroyed and obviously no longer hermetic.
But, on the other hand, it became clear that no lubrication was not possible before. No needles, no guns.
Sorry for my poor English.
Old Feb 28, 2012 | 03:30 AM
mr.xtype's Avatar
How did you get the shaft off of the bearing?
Did the part you replaced come right off or did you need special tools to do it?
Lomg story short... is it fixed and working properly or are you in need of a new shaft?
Old Feb 28, 2012 | 10:51 AM
Luka's Avatar
Repair is successful. Just do not know how long it will last.
I will give a report.
Old Feb 29, 2012 | 03:33 AM
mr.xtype's Avatar
Luka how did you get the bearing off? What toold were needed? Do you just pry it off or do you need a press to do it?
Can i do this in my garage with basic tools?
Old Feb 29, 2012 | 10:23 AM
Luka's Avatar
No special equipment is needed. The pictures are arranged in order of operations. I only used a hammer and chisel. The third photo shows the ring in which I hit and is deformed by blows.
Besides these two rings which are visible on the second and third picture, there are two inwards and sealed with rubber. They can also be distorted when pulling them.
I also did all that in my garage by myself.
Old Feb 29, 2012 | 06:31 PM
iownme's Avatar
I just ordered a replacement shaft on ebay for $150 inc shipping. The rubber inside my carrier is shot I,m sure and I have 3000 miles to do in the next 2 wks.
My new bearing is up for sale for $15...pm me if you want it
Old Dec 15, 2013 | 01:49 PM
04xtype04's Avatar
Is it possible to grease the 04's driveshaft bearing? Was thinking of getting a grease gun with a needle tip but will this get grease in the bearing?
philwarner
Oct 4, 2024 01:37 PM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
innzane
Sep 2, 2015 10:08 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
