Is this the prop shaft bearing??
Old Oct 8, 2013 | 01:39 PM
Spikepaga's Avatar
Default Is this the prop shaft bearing??
Hello guys,
I took my car to an axle rebuilt shop I trust to have them look at my propeller shaft to figure out why my car sometimes vibrates when I am accelerating and then let of the gas and accelerate again. They said this is the culprit:
They said they can rebuilt it if I find the rubber bearing (?).
Is this the part that commonly makes these cars vibrate like mine?
Thanks!
Attached Thumbnails Is this the prop shaft bearing??-null_zpsc421eef3.jpg   Is this the prop shaft bearing??-null_zps1bd19e29.jpg
Old Oct 8, 2013 | 02:08 PM
reyesl's Avatar
Here is a link to a post with some info on the hanger bearing:
https://www.jaguarforums.com/forum/x...e-shaft-68483/
Old Oct 8, 2013 | 06:43 PM
Thermo's Avatar
Veteran: Navy
Spike, yes, that is the infamous prop shaft bearing that everyone talks about. I would say to first grease the bearing and see what you have at that point. Then determine if you need to replace the bearing at that point. Normally if you catch the vibration early, a little bit of grease will get things back to 100%.
Old Oct 9, 2013 | 09:53 AM
DPK's Avatar
DPK
Look at these series of pictures RE: Prop Shaft Greasing..
They were provided by a very helpful and genuine X-type enthusiast..
Jaguar Forums - Jaguar Enthusiasts Forum - jfenley's Album: Grease Prop Shaft Support Bearing - Picture
Old Dec 14, 2013 | 05:44 PM
04xtype04's Avatar
I should do this to my car before it goes bad. Found the needle adapters on ebay pretty cheap. Need to get a grease gun and a jack too though.
Old Dec 14, 2013 | 06:39 PM
Pinecone's Avatar
So THAT is what a nine year old car looks like without rust underneath. It needs to drive around the north east for a bit and get it properly seasoned, Mark.
Wow that is too clean.
Let me know when you are ready for a new car...ones from Texas are just what we need here.
Tom
Old Sep 2, 2022 | 09:17 PM
Ena_ii's Avatar
Thermo Can some one please confirm that when the bearing slides down the prop shaft(aft) does it easily clear the balance weight on the end of the prop shaft shaft or does the balance weight need to be removed and relaced?
Old Jun 10, 2024 | 03:28 PM
Backhertz's Avatar
Realize this is an old thread. When I replaced the center bearing on my propshaft, the bearing easily cleared the weight on the rear of the propshaft. Would not suggest removing the weight.
trickeyM
Oct 4, 2015 05:43 PM
inactualis
Oct 2, 2015 11:13 AM
Nic1635
Oct 2, 2015 01:30 AM
millertic
Sep 30, 2015 08:11 PM
