02 x-type won't drive forward but will drive backwards ?
Old Jul 16, 2011 | 07:56 PM
st.clair's Avatar
Question 02 x-type won't drive forward but will drive backwards ?
We have a 2002 x-type jaguar with a 2.5 it has an automatic tranny . That won't move forward but will go backwards fine. the car was in an crash. It hit the guard rail in the front corner and back corner on pasinger side . The front tire was not hit . just the fender took the hit . Then it sat for the winter till it went for body work and when we tried to drive it on the flat bed truck it fees like its in second or third gear . I just don't wont to go but it does move . Is there a way to check the line pressure ? Is it shifted by electric or is there a cable ? I do mechanic and electric work so I under stand the lingo . thanks for your time and any info .
Old Jul 31, 2011 | 12:52 AM
st.clair's Avatar
Default 02 x-type auto transmition wont shift in to drive
When i shift to drive it goes but it feel like its in 2 or 3 gear, but when i shift to reverse it goes just fine.
Old Jul 31, 2011 | 07:48 AM
Thermo's Avatar
Veteran: Navy
st. clair, it is possible that the car is in 2nd gear right now. If the computer sees an issue with the tranny (internal mechanical problem or electrical), it will attempt to shift the tranny into second gear and then leave it there for the forward movement. It is possible that you shocked the tranny and something gave inside the tranny or you have somehow hurt the wiring going to the tranny. Without doing detailed inspections of the car, it is hard to say what it could be. Connecting up a higher end analysis computer should be able to give some clues as to what the computer is seeing which can lead directly to the source of the problem. By chance, is the ABS light on now?
Old Aug 1, 2011 | 04:49 PM
st.clair's Avatar
can any shop check it or do I have to take to a jaguar dealer ? and I will give it a good look over for any wires off or damaged. are the solinoid inside the transmission or on the out side ? thanks for your time
Old Aug 1, 2011 | 04:53 PM
Thermo's Avatar
Veteran: Navy
st.clair, any tranny shop should be able to diagnose the tranny for you. As for rebuilding it, I would look for someone that is a bit more familiar with this type of tranny than "Ed's service" on the corner. As for the solenoids, you need to drop the bottom pan of the tranny to access them. So, you are atleast into a drain and fill of the tranny.
Old Aug 1, 2011 | 05:06 PM
st.clair's Avatar
sorry there is no ABS light on
Old Aug 1, 2011 | 05:11 PM
st.clair's Avatar
Ya if its time for rebuild it will for sure go to a jaguar dealer for love and care , Not to say bad things about our tranny repair shop . Its just me .
Old Aug 1, 2011 | 05:19 PM
st.clair's Avatar
with all I have read about trans fluids I'm still not surewhat to use. Is the castrol import multi-vehicle ATF is what i was going to use what do think.
Old Dec 3, 2011 | 06:40 PM
st.clair's Avatar
new tcm fixed the problem. On the road again. Thanks evry one for the help. Have a grate new year.
BrentGardner
29
Dec 16, 2024 12:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
Newsguy
Aug 30, 2015 11:27 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
Terencex
Aug 26, 2015 08:47 AM
