1996 XJS RH A/C, Heat fan will not stop
Old May 25, 2019 | 11:01 AM
Sonny_D's Avatar
Default 1996 XJS RH A/C, Heat fan will not stop
I have an interesting problem. Right side blower fan will not stop running even when the car is shut off. I have to go and take the fuse out the fuse box to stop the fan otherwise battery will be drained. I have seen similar posts about a relay getting stuck in an open position thus it keeps running since the fuse feeds power to it.
However I can't locate the relay that controls the right blower motor fan. to add to the frustration it keeps bringing hot engine air. With summer heat it's becoming difficult.
Not sure if the same relay would effect the A/C control panel. The temperature and fan speed knobs don't work as well.
Please Help
Old May 25, 2019 | 01:31 PM
avern1's Avatar
Unfortunately you have posted your question in the wrong forum category. This section is for the X-Type. You need to post in the XJS forum.
Follow the link below and post you question there. Jose will chime in and help you out, I bet.
https://www.jaguarforums.com/forum/xjs-x27-32/
Old May 25, 2019 | 04:26 PM
Dell Gailey's Avatar
https://www.justanswer.com/jaguar/4b...ble-today.html
https://www.jaguarforums.com/forum/x...or-help-48306/
Spikepaga
Sep 15, 2021 08:20 AM
Tibbetts
Jun 4, 2019 03:06 AM
John Mitch
May 22, 2019 05:44 PM
Creedmoor1878
May 10, 2019 04:13 PM
4seasons
May 7, 2019 04:04 PM
