2.0d rattle
Old Apr 14, 2019 | 01:55 PM
k_gopsill's Avatar
Default 2.0d rattle
Hi, i’ve just changed my crank pulley, tensioner and belt and my rattle hasn’t been solved, and goes louder when i put the aircon on. Do you think the tensioner i bought could be faulty?
Old Apr 15, 2019 | 02:08 AM
DUNKS's Avatar
Default Tensioner
If you bought a new tensioner I would consider it most unlikely. You say you changed it yourself? Perhaps time to let a professional look at it. Might save you money in the long run.
Old Apr 15, 2019 | 11:11 AM
Hex Type's Avatar
Have you checked the air con compressor? if the pulley on the compressor is faulty it makes a similar noise to the crank but when engaged the air con should technically make it sound less
Old Apr 29, 2019 | 06:49 PM
Luke Farrell's Avatar
have a look down at the belt when the car is at idle and if the belt is jumping then maybe the new tensioner is bad, did you tighten everything properly too? look at the crank too when its moving,
if everything is okay then turn on the aircon and look at that pully and see if its not running smoothly
Old Apr 30, 2019 | 02:17 AM
k_gopsill's Avatar
Thanks for your help, turned out it was a faulty crank pully, put another one on (heavy duty) and that’s cured it!
Old Apr 30, 2019 | 07:41 AM
Ahh brilliant!
I did a bit of research on them before in case I ever had to replace one , heavy is definitely better, I think the old light ones all ran into problems.
I read somewhere else that people put in the couple style pulley from the transit vans and that worked great , you might need to get a new housing for around the wheel arch tho
Do you have the pulley reference number or make of it so I know what to get when mine goes
Old Apr 30, 2019 | 08:23 AM
k_gopsill's Avatar
Yes, got it off ebay item number 261737281496, car is now rattle free!!
Old Apr 30, 2019 | 05:23 PM
Thanks! Hopefully it will stay good for a couple of years at least if not longer.
If it ever breaks or has problems do let us know back on this thread
mfennell
Jul 30, 2019 10:43 AM
Whirlinturbin
Jan 10, 2016 08:20 PM
Jul 21, 2013 04:30 PM
bojangles
Jul 11, 2007 08:56 PM
scchuck
Sep 11, 2006 09:48 AM
