2001 x type turning but not firing up
Old Jan 26, 2015 | 07:49 AM
officer837's Avatar
Default 2001 x type turning but not firing up
Hi all,
any help here,, i have a 2001 x type jaguar 2.5 petrol automatic.
Been stood for a while, went to start and dead battery, so i put on a new battery. Turns but just doesnt seem to fire up. Sprayed some carb spray in, and it fires but then dies.
Car was running fine last time i drove it, so very confused.....
any help?
Karl
Old Jan 26, 2015 | 12:13 PM
Thermo's Avatar
Veteran: Navy
officer, from the sounds of things, because you can make the car run on carb cleaner (if only for a second or two), this pretty much confirms that your problem is with the fuel pump and/or the power to the fuel pump (coming from the ECU). I would first check the inertia switch (footwell area by the driver's right foot in your car). After that, you would most likely be replacing the fuel pump.
Let me double check the diagrams. There might be a fuse/relay associated with the fuel pump, but not recalling off the top of my head. Could be something that simple.
Old Jan 27, 2015 | 01:27 AM
officer837's Avatar
Hi
Thanks for that
Check it and that didn't fix it,,
Old Jan 27, 2015 | 03:32 AM
Paulc732's Avatar
Check your fuel pressure.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
celticpiping
Sep 18, 2015 06:17 PM
cheaperts
Aug 30, 2015 06:48 PM
dpappyp
Aug 27, 2015 06:31 AM
