2002 cooling probs
Old Jun 17, 2014 | 02:21 AM
charliebs's Avatar
Default 2002 cooling probs
Hi all hope you can help ?
My jag keeps over heating ????
By this I mean the temperature gauge suddenly drops then races up to the red and all hell breake's loose !!! No cruse controll ! Engine over heat !!! Warning lights !!!!
If I pull over to the side of the road and turn the engine off for about 30 seconds and restart all goes back to normal for half an hour or so ??? Please can anyone help me ??
Old Jun 17, 2014 | 02:39 AM
Welcome to the forum Charlie,
I've moved your post to the X Type section, please drop by the new members section when you can and post an intro.
Old Jun 18, 2014 | 07:10 AM
Thermo's Avatar
Veteran: Navy
charlie, it is sounding like you are having an issue with the engine coolant temperature (ECT) sensor. The sensor is getting a bit warm and then reaches a break over temp and goes into a failure mode. Start with replacing the sensor and doing a visual of the wiring. Then lets see what you have at that point. Another thing before you replace the sensor, get the codes reads. That may give me a bit more confidence that it is the sensor that is bad by the code you get. Granted, also do a quick look at the level of the coolant in the overflow bottle. If you are running low due to a slow leak, that may be the source of your problems too.
Old Jun 22, 2014 | 04:48 PM
ditenorio's Avatar
I'm having the same problem.. I usually put the heat on. Even though this time of year would call for my air conditioner to be on. The heat being on usually brings the engine temp down to normal. My jag overheats just driving in stop and go traffic and when I let the car idle for more than 20 minutes. I dont know what to do.. Thermostat?? Sensor? dont know..
Old Jun 23, 2014 | 08:17 AM
Thermo's Avatar
Veteran: Navy
ditenorio, see my post in your other post. I think your problem is more fan controller based, not sensor related.
LilaJagHubby
Oct 1, 2015 01:47 AM
gunlocators
Sep 30, 2015 08:05 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
jjmiah217
Sep 28, 2015 09:09 AM
jessejamestw23
Sep 26, 2015 03:57 PM
