2002 x type
Have an issue with a washer fluid leak somewhere, does anybody know
the fluid tubing routing around the right front engine bay?
Thanks for your help guys
Walter in New Mexico
Fill it up with water, run the pump, put a piece of cardboard under the car and see where it gets wet.The washer bottle is in the right fender behind the head light.If you need to remove it there is relatively new new post on how to access it. eg. remove inner tire well,bumper cover.Not a usual spot unless there was car damage. More likely one of the hoses to the spray head on the hood have broke.Both of mine broke. There are one way valves in the system to equalize pressure,(one by each head).Also check the hose where it goes around the hood hinge.
KarimPA
Sep 3, 2015 07:32 PM
