2002 X Type 3.0 blue smoke on startup?
Old Nov 2, 2007 | 02:49 PM
tokaygecko's Avatar
Default RE: 2002 X Type 3.0 blue smoke on startup?
I am pretty sure that if the car only smokes for a little bit after sitting then it is the valve seals. If you let the car idle for 15 mins then take off, do you get the same blue puff of smoke? If so then it is probably the valve seals.
I can't see removing the cams taking more than 6 hours. The whole job can probably be done in a day by an experienced tech, or over a weekend by a mechanically inclined person.
Old Dec 23, 2007 | 06:34 PM
aquill1's Avatar
Welcome!
Is there a reason to do this or wait til its a bigger problem? If it were necessary to do every single cop car or old persons car would need this as they all blow out smoke...
Old Apr 23, 2008 | 03:46 PM
FactoryJaguarTech's Avatar
I was gonna say about the PCV valve. 2002 had bad ones, but it was more of a huge cloud of smoke when you took off. I remember changing one and filled up the whole street with smoke when I went driving it because of all the oil in the intake manifold....lol
Old Apr 23, 2008 | 04:38 PM
aquill1's Avatar
Ewww...that doesn't sound great...
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
way2far
Aug 31, 2022 09:26 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Raul Lara
Sep 14, 2015 07:31 PM
dcvickers
Sep 2, 2015 06:14 PM
