2003 Jaguar X-Type brakes locking up
Old Dec 9, 2018 | 09:38 AM
Cwhite71's Avatar
Default 2003 Jaguar X-Type brakes locking up
Hello, I have a 2003 Jaguar x type. I have replaced the brake booster twice, placed a new master cylinder, and ABU unit. My brakes are still locking up when driving. Could you help on this?
Old Dec 9, 2018 | 09:50 AM
Welcome to the forum Cwhite71,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Old Dec 9, 2018 | 01:22 PM
Thermo's Avatar
Veteran: Navy
Cwhite71
Read post 4 in the link. That should fix what you have going on.
https://www.jaguarforums.com/forum/x...ocking-211141/
Old Dec 9, 2018 | 09:57 PM
Cwhite71's Avatar
Default Brakes locking up
Will this also take out all the pressure thats in the pedal?
Originally Posted by Thermo
Cwhite71
Old Dec 10, 2018 | 07:27 PM
Thermo's Avatar
Veteran: Navy
Cwhite71, yes it should. What you have is the brake booster is not able to relieve the pressure and it is building up, causing the brakes to engage and give you that hard pedal feeling. Once you get it properly adjusted, the pressure can relieve and all will be good.
Old Dec 11, 2018 | 06:09 PM
dennis black's Avatar
20 Year Member
dont buy another booster again its a simple adjustment 15min job without taking any hoses of ...just unbolt the master cylinder whatch not to drop the nut on the right ,pull back the booster out the way , have friend push the brake pedal all the way in now you can see the rod ...now get a needle nose pliers and hold the shaft ,then put a 7mm socket on the end and turn it in about 3-4 turns clockwise in ...and voila your done ...
Miguel Orozco
Nov 5, 2018 09:16 PM
Jeppy
Nov 5, 2018 01:56 PM
Spiros C. Kouris
Nov 5, 2018 12:44 PM
LnrB
Nov 1, 2018 06:52 AM
Realtorman
Oct 31, 2018 04:09 PM
