2003 Jaguar x-type ringing in cabin
Old Jun 8, 2018 | 10:19 PM
Duck991's Avatar
Default 2003 Jaguar x-type ringing in cabin
i have this ringing/ humming noise in my car, the keys is not in the ignition, and every time i disconnect the battery it goes away. is this normal?
Old Jun 9, 2018 | 12:35 AM
sov211's Avatar
That is the sound of the small aspirator fan for the climate control - located to the right of the steering column, behind a small grille. This fan begins to run when you pull the driver's door handle and remains in operation for a half hour or so after the engine is shut off...and this is indeed normal. Sometimes the fan gets noisy, principally when loaded with dirt sucked in over a period of years. It can be removed and cleaned and this often reduces the noise.
Old Jun 9, 2018 | 12:55 AM
dwclapp's Avatar
+1 for the in-cabin temperature / humidity sensor. Google part # C2S13944 for pictures, for example: https://www.terrysjag.com/category/X...nd-Sensor.html
A picture of the same part in an S-Type is here, at the bottom of the long page: DIY: Diagnose It Yourself - JaguarClimateControl.com
Old Jun 9, 2018 | 01:35 AM
Duck991's Avatar
Omg thank you so much
Old Jun 9, 2018 | 03:39 AM
Dell Gailey's Avatar
When I cleaned mine, it coughed up a hairball.
Old Jun 9, 2018 | 09:32 AM
dwclapp's Avatar
Now that you know the source of the noise, you could respond to passengers with: "What ringing sound? I don't hear any ringing sound."
https://en.wikipedia.org/wiki/Gaslight_(1944_film)
Old Jun 9, 2018 | 04:52 PM
iownme's Avatar
its your iphone
take it out of your pocket and slide the mute button to "on"
Bcrowie
May 2, 2014 11:06 PM
jerry814
Dec 6, 2013 02:28 PM
ku1d33p
Feb 19, 2013 03:42 PM
oldjaglover
Jun 28, 2012 04:16 PM
pcc
Sep 15, 2009 06:05 PM
