2003 X-Type indoor air sensor wont turn off. What do I do?
Old Oct 24, 2009 | 04:06 PM
Thermo's Avatar
Veteran: Navy
KXUNA, if you look at the sensor, it will have a white/red lead and a black/white lead. The white/red lead is where power comes in and the black/white lead is switched by the A/C control module. So, odds are, what you will need to do is disconnect the plug from the A/C control module and see if the fan continues to run. If it don't, then you are looking at a bad A/C control module. If the fan continues to run, then you have a wiring problem.
If you need more help, let me know and I will go into more detail about this.
Old Oct 24, 2009 | 06:24 PM
Colt's Avatar
Banned
It looks like this..(These are Kaco's pictures)
Old Dec 5, 2009 | 09:21 AM
ArmyNCO63's Avatar
Default same problem
I am having the same problem where is this part located?
Old Dec 5, 2009 | 11:13 AM
jimmy's Avatar
ud
Are you certain it is running? all the time?
the little fan runs for a few minutes after switching the car off, and then re-starts when you open the door.
Unless you sit in the car for a while after the key is off, (maybe even door needs to open and close) the fan will always be running whenever you are in the car.
have you hooked up an amp meter in series with the main battery post, and pulled fuses one by one until you find the offending circuit? There is a very systematic way to trouble shoot a current drain on the car. Make no assumptoins.
BrentGardner
29
Dec 16, 2024 12:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
Aranon
Sep 3, 2015 07:56 PM
Gmiles
US Western
Aug 31, 2015 05:48 PM
kesslari
Aug 31, 2015 04:53 AM
