2004 X Type lost coolant in a crack on plumbing part in front of the Radiator
Old Jul 28, 2016 | 07:18 PM
Lorraine Burke's Avatar
Default 2004 X Type lost coolant in a crack on plumbing part in front of the Radiator
I am looking for help in finding what the part is that has a crack in it. The car had been parked due to tags and once I had taken it to go put a little air in the tires, it sprang this leak. By the time I got to the gas station, about 10 min away from home, it had let all the coolant out. I refilled it and drove it back home and it maintained most of it but quickly let most of it out. I discovered the leak was located on a part (I called it the plumbing for lack of a better word) located in front of the radiator. My son-n-law pointed the leak out and I was wondering if anyone knew the name of the part and if it is an easy fix? I don't want to chance driving it back into town and I don't know a mechanic. I am afraid of them taking advantage of it being a Jaguar as well and charging me an arm and a leg. I included two pics of the leak.
Attached Thumbnails 2004 X Type lost coolant in a crack on plumbing part in front of the Radiator-13835643_10205116175264107_1743872373_o.jpg   2004 X Type lost coolant in a crack on plumbing part in front of the Radiator-13835751_10205116175824121_454160070_o.jpg
Old Jul 28, 2016 | 08:17 PM
avern1's Avatar
I have attached a parts diagram for the cooling system. I think you are looking at piece 7 on the diagram. You can compare the pictures to your actual hoses.
Also I included the excerpt from the JAGBITS parts site for piece 7
File Type: doc
Old Jul 28, 2016 | 11:59 PM
Carznguitarz's Avatar
Default Upper coolant leak(crack)at the "T" fitting
Same problem here. Drove it for a year with minor loss. Filled the reservoir once a week. The the crack finally let go, Not able to drive losing that much fluid. Found a product for an "emergency fix" called "stretch and seal" at Homedepot. Clean the " T " pipe well and do a figure 8 wrap nice and tight around it. This fix works well until you can get the replacement. Got my replacement hoses complete on ebay with free shipping for $100.00.
Hope that helps.
Old Jul 29, 2016 | 01:49 PM
x_type_lpg's Avatar
looks like the thermostat housing.
Old Jul 29, 2016 | 03:41 PM
Thanks everyone for your information. I ordered the part and will update when my son-n-law installs it
Old Jul 29, 2016 | 06:33 PM
Everyone was so helpful. Thank you, I ordered the part today.
Old Sep 15, 2016 | 10:49 PM
Thang Nguyen's Avatar
It's the upper radiator hose assembly, you have to buy the whole assembly, go on ebay to find one is cheaper auto parts store.
Addy
May 23, 2016 10:13 AM
Peter Langan
26
Apr 6, 2016 01:42 PM
Noel619
Apr 4, 2016 08:18 AM
RonaldP
Mar 30, 2016 02:34 PM
dartech
Mar 27, 2016 11:43 AM
