2004 X-Type Window Pillar Cloth trim
Old Aug 26, 2013 | 10:04 AM
Backhertz's Avatar
Default 2004 X-Type Window Pillar Cloth trim
For some reason the cloth on the pillar trip has decided to separate & flaps as I drive. I noticed some people have opted to spray fabric paint repair. I contacted another member who suggested I try upholstery spray adhesive. That is what I am going to do.
The plastic trim piece was easy to snap out. I noticed I also have a problem in the rear. I noticed the rear pillar cover says Air Bag. I'm not sure if this cover comes off as easy as the front & figured I'd ask you guys.
Attached Thumbnails 2004 X-Type Window Pillar Cloth trim-img_0146.jpg   2004 X-Type Window Pillar Cloth trim-img_0147.jpg   2004 X-Type Window Pillar Cloth trim-img_0148.jpg
Old Aug 26, 2013 | 11:55 AM
Backhertz's Avatar
The 3M Adhesive did the trick and the pillar covers look brand new. Hopefully my headliner will not suffer the same plight.
Old Aug 26, 2013 | 03:45 PM
Backhertz's Avatar
Default X-Type Rear Window Pillar Cloth
Unlike only clips for the front window cloth pillar trim, there is a 10 mm bolt securing the rear. I removed the bolt & the trim piece came out. So now all my window pillars no longer are flapping after using 3M Upholstery Headliner Adhesive. Spray it, wait 5 minutes and carefully press the cloth down. Bada bing, bada bang.
Old Aug 4, 2018 | 04:14 AM
trevor burnett's Avatar
Thumbs up trevor burnett
can you let me know where to get the fabrick to replace the apast gover
Old Aug 4, 2018 | 01:10 PM
Dell Gailey's Avatar
10 second Google search =
https://www.ebay.com/i/262217890510?...036cf8fff40e99
Old Aug 4, 2018 | 02:38 PM
Davenwalee's Avatar
Not all pillars have cloth some xtypes came with just plastic. The cloth was coming off and I found plastic ones on another xtype at the junkyard
Old Aug 5, 2018 | 05:03 AM
MTypeX's Avatar
Mine were coming off and dirty too (from the previous owner), I took the pillars off, completely removed the cloth and went to a textile shop and bought the same color. Cut the exact shape and pattern and then used 3M adhesive spray. The pillars look like new now.
silkcat
Jan 18, 2025 04:29 AM
way2far
Aug 31, 2022 09:26 AM
Thang Nguyen
Oct 12, 2015 01:25 AM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
