2007 jaguar xtype misfire cylinders 1, 3 and 5 and p1313 code.
Old Jul 10, 2018 | 07:15 PM
camrongalaviz's Avatar
Default 2007 jaguar xtype misfire cylinders 1, 3 and 5 and p1313 code.
I powerwashed my engine bay, and when I finished I recieved 3 misfires and usually they go away because well the water finally goes away. it's been a week and still missing. I've taken of the intake manifold changed the gaskets, sucked out the water, and clean out the spark plug chamber multiple times. I pulled a coil with a spark plug out to test the spark and it was sparking so I have no idea what it could be. I smell tons of gas. Cant go past 3000 RPMs.
Old Jul 10, 2018 | 07:21 PM
NBCat's Avatar
Did you dry out the wiring looms and connectors?
DTC P1313 indicates bank A catalyst is probably damaged by raw fuel being burned inside the catalyst.
Correct the misfires before driving the vehicle any further as it may now need a new Bank A catalyst.
Old Jul 10, 2018 | 07:30 PM
yes there has always been a cat code. I'm fixing that problem soon but as far as cleaning water out of the wiring looms and connectors which ones exactly should I be looking for to clean the water out off in paticular.
Old Jul 10, 2018 | 08:16 PM
Dell Gailey's Avatar
Did you learn a lesson about spraying out an engine compartment?
Heed post #7=
https://www.jaguarforums.com/forum/x...leaning-78380/
Old Jul 10, 2018 | 08:17 PM
I've done it plenty of times. I'm quite sure it's because it's a jaguar.
Old Jul 10, 2018 | 08:18 PM
In that link also note to NEVER USE A PRESSURE WASHER.
Old Jul 10, 2018 | 08:21 PM
My BMW's were the same eay. What really pissed me off was a "foreign car specially" shop did just that. Took them 2 days and some good old fashion greenbacks to fix what they screwed up. Needless to say, I changed shops after that event.
gShawn
Jun 14, 2022 03:21 PM
catmando
17
Feb 17, 2017 02:13 PM
twncty
Jun 6, 2016 12:42 PM
disgruntled
Sep 15, 2009 12:45 PM
carter
Dec 22, 2008 06:46 PM
