2008 X type 2.2 Diesel Bonnet lock will not open.
Old May 12, 2021 | 01:45 PM
essence head's Avatar
Default 2008 X type 2.2 Diesel Bonnet lock will not open.
Went to open my bonnet this morning and lock will not function on one side. I looked and saw that it is a common problem and I followed the advice to open it manually from underneath. I put the car up on ramps and removed the plastic tray from under the bumper and although I can see up side of rad I cannot see the lock mechanism. Video shows it being opened with a long bar but I cannot even see the lock. The one in the video is a 2003 so is there a difference with the later models? Can anyone give me some ideas of how to go about opening it please.Do I need to remove all the under trays ? or is there another way of opening it. Thanks in advance.
NOW GETTING A BIT DESPERATE. on my model you cannot see the latches from underneath !!! have seen some posts about going in through the wheel arch ?? anybody have any experience of this problem please PLEASE.
Old May 12, 2021 | 03:49 PM
Dell Gailey's Avatar
Old May 13, 2021 | 12:53 AM
Thank you but already viewed this....still cannot open bonnet (hood) maybe I am just a dumb ***.
Old May 13, 2021 | 03:02 AM
Really? Not hard, just awkward. You can see the latches from under the car. Make sure you're pushing the latch the correct way. Couple of years ago a guy was struggling and was pushing the latch the wrong way to release.
Old May 13, 2021 | 04:32 AM
I have now had 3 guys look under car and nobody can even see the latches. Can only assume that the later models are designed differently , mine is Dec 2008 model. but thanks anyway Dell.
Old May 13, 2021 | 01:32 PM
Heed = "did you remove undercarriage skirt first". "Are you moving latch towards CENTER of car".
https://www.jaguarforums.com/forum/x...lz-help-15313/
Old May 14, 2021 | 03:16 PM
max224's Avatar
Had a similar problem with my 05 Estate Wagon. To the best of my knowledge, the hood release mechanisms are the same on all of the X-types. The only variable I see that's possibly relevant different is the diesel engine. When I got mine open it was by removing the plastic underpan, crawling under the car and pushing the release levers with a long screwdriver. They are easilyvisible and, unless your hood release cable is broken, you should be able slide a screwdriver along it and push the lever the cable is attached to. It was difficult and lrustrating as was running the new cable into the engine compartment.
Nothing more I can suggest except wrapping a zip tie around the release lever and the cable so it can't fall off; that was the problem with mine. Good luck!
Old May 15, 2021 | 12:59 AM
Hi Max, thanks for that info. Did you remove all the plastic underpans?.....I have only removed the front one under front bumper. At least I know it can be done and all years are the same design. Will get back on it today....if it stops raining. Thank you
Old Jan 3, 2022 | 08:07 PM
MitchellSS1's Avatar
Hi, did you ever get to the bottom of this? I’m having the EXACT same problem with a 2008 2.2 D, cannot see the catch at all! Tried taking wheel liner out still no luck.
Hope you got it sorted and would love to h us how you did if so we we’ve exhausted ideas.
Old Jan 16, 2025 | 01:49 PM
Jag22?'s Avatar
Default Solution
went to open my bonnet this morning and lock will not function on one side. I looked and saw that it is a common problem and i followed the advice to open it manually from underneath. I put the car up on ramps and removed the plastic tray from under the bumper and although i can see up side of rad i cannot see the lock mechanism. Video shows it being opened with a long bar but i cannot even see the lock. The one in the video is a 2003 so is there a difference with the later models? Can anyone give me some ideas of how to go about opening it please.do i need to remove all the under trays ? Or is there another way of opening it. Thanks in advance.
Now getting a bit desperate. On my model you cannot see the latches from underneath !!! Have seen some posts about going in through the wheel arch ?? Anybody have any experience of this problem please please.
solution:
Take out back screws from front panel under car - remove screws from next panel back, slide back and remove - gap between radiator and front of engine alows a really long screwdriver or rod (80cm min) to be inserted upwards to pull back the lock - i've watched my mechanic do it so i know it can be done. Most likely that the cable has come loose from the catch, not snapped - remove catch assembley and search for loose cable - you will have to attatch cable to latch - crimp really hard to make sure it will never come off again - insert catch mechanism back from under holding slot (it can be done but, you will have to pry it up through the hole) - bonnet pull lever should now work - forgot to mention - you will also have to remove top engine cover to get your hand down back of latch assembly hole - i'm assuming you realise car will have to be put on lift to get underneat to do this) - with trial and error this took 2 hours of my mechanics time (really, i was there!).
Bad news:
Old May 11, 2026 | 11:34 AM
picklefactory's Avatar
Hi folks
I know this is an old thread, but just had the same issue with the same model, so thought I'd add.
Just to confirm essence head is quite correct. I've also got the 2.2 diesel and all the lovely views I've seen of the latches from underneath are NOT there on this model, there is zero access from underneath, just a mass of pipes and oil cooler with no way through to either side latch. I tried the same route, as my left hand latch (Passenger side, RHD car) also would not release. Undertrays removed, up on ramps but you cannot even see either of the latches from underneath. I also got a second set of very experienced eyes to come and check I wasn't blind or daft.
I was lucky on mine in that the right hand latch did pop and the way I managed, after about 3 very sweary hours, was that I managed to get a pry bar under the bonnet near the bad latch and carefully lever some room. I heated and bent a right angle on a thin flat blade screwdriver, to make it L shaped about 1" from the end with the blade parallel to the shaft. I could just about get to the top of the latch at the pivot end and there is a very small shoulder on the top that with much fiddling I managed to get a bit of purchase and flip it. Again I was lucky that the latch is in good order and free moving, hey presto I'm in, but I was beginning to despair.
I hope that helps someone else with the 2.2D engine
carzaddict
Sep 19, 2023 11:09 AM
Joe Gandalf
May 11, 2021 11:46 PM
Muhammad Umer
Nov 21, 2016 04:23 PM
f_in_seattle
May 27, 2015 01:00 PM
1strider
Sep 3, 2010 01:16 AM
